Question about Belkin Play N600 Wireless Dual Band Router (722868807453)
My belkin n600 keeps saying no internet connection the light is orange but the computer registers the router
How do i fix it i have it plugged into the modem and the computer connects to the router but it wont connect to the internet
    Problem Solver:
  • 10 Answers
Alright. The orange light means the router has no problems with your inner (private) network or its internal configuration, but it can't connect to the internet by itself. So obviously, your devices, which are routed trough your router, won't be able either.
I've compiled a small list for things you can check to resolve this issue:
- Check if your ethernet cable is connected to your router. It can be a CAT5 DSL cable or a CAT5 cable from your modem, to your router.
- Log onto your router configuration panel on http://192.168.2.1/ or http://router/ by clicking log in at the top (the default password is blank). Should you get any problems with logging in, you might need to reset your router (button on the back, hit once for restarting and hold for 10 seconds for factory reset).
- Your problem is with WAN (Wide Area Network) or the outer network, so you will want to focus of that area of the configuration panel. Hit "Connection Type" and make sure you configure it accordingly to your ISP. If not sure, you can try and check the LAN/DSL configuration on another device that can connect to the internet via an ethernet port (the CAT5 from your ISP or modem) or just try the "Automatic" option.
- Check out the "DNS" section in the "Internet WAN" section. If unsure, try setting it to automatic. This will inherit the settings from a parent device in the network.
- Working with MAC addresses can be tricky. They are the fingerprint of your internet device (router, computer, LAN switches, modems) and some ISPs register your devices for security purposes. You should probably call your ISP and ask about it, if they need this configured specifically, they'll tell.
- If you're using a number of routers or a modem and a router you may need to change your LAN subnet mask or routers IP address in either your modem or one of your routers settings. This is only necessary if they overlap on multiple devices.
I have to say, though, 99% of the time it's either cables left unplugged or DNS misconfigured.
Posted on Apr 23, 2013
sandrew
  • 2961 Answers
SOURCE: Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Posted on Mar 07, 2007
Mtnhorse
SOURCE: Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Posted on Aug 18, 2007
SOURCE: i have a belkin n wireless router keeps freezing
I have the same problem on my fd57633au the problem only appears when i use torrents.. i believe the modem cannot handle too many open connections (tho i am still unsure) currently testing now limiting outgoing connections and it appears to be working fine (i can normally get the moment to halt within 5mins)
Posted on Nov 09, 2008
SOURCE: modem light flashing, can't connect when the router is plugged in
The belkin website is here http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=1564&scid=0 richardm69
Posted on Dec 06, 2008
  • 50 Answers
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Posted on Apr 21, 2009
Belkin n600 db wireless n+ router stopped working
Your Belkin Router Has Stopped Working And You No Longer Have Wireless Internet Please Follow these Steps To resolve this issue
  • Restart Your Router And Modem.
  • Make Sure Internet Service Is Running Fine Via Internet Service Provider.
To know more info visit at Belkin Support And Belkin Router Troubleshooting Guides TechVaidya After All, This If Your Belkin Router Did Not Work Just Reset Your Belkin Router Using The Reset Key and Setup Your Router Again[Don't Worry its Easy and Simple And I Will Guide You How to Setup The Belkin Router.
Oct 14, 2012 | Belkin N600 DB Wireless Dual Band N Router
For belkin n600 router, how do i set access controls so i can allow/deny different times for different days. is there a grid which shows all 24 hours for each of the 7 days of the week?
To Crack This Confusion Between Router Users And Clear The Concept
1.Router Password And Wireless Network Password Is Totally Different Things.
2.
While Router Password Locks and Prevent unauthorized access To Router Settings and Configuration.
3.
Wireless Password Makes The Wireless Internet Secured And Allow Only Users Who Know The Password.
for more you need to visit https://fixingblog.com/lock-and-secure-belkin-wireless-router/
It may help full for you
Sep 05, 2012 | Belkin N600 DB Wireless Dual Band N Router
My belkin N450 DB was working fine, but now I have a solid amber light and cannot connect to the internet on any laptop or PC. whats up?
you want to more strong internet connection then
Set up Belkin router as per these steps
  • Restart Your Belkin Router And Your Internet device.
  • Please Update The latest Firmware for Belkin Router.
  • Just Login To Your Belkin Router Using 192.168.2.1 and Check For Updates.
  • Check Your Computer And Devices For Virus Or Junks. Read More How To Get Slow Windows Computer Faster In 10 minutes
  • Change The Channel Settings In Your Router.
  • In Case You Think Doing All this Did Not Help I think It's Time You Get A Range Extender That Can Get Your Signal strengthen.
If you need to more info regarding it Please visit Belkin Support And Belkin Router Troubleshooting Guides TechVaidya
Feb 04, 2012 | Computers & Internet
My belkin N600 router will not connect to my internet
Router should be connected via RJ11 cable to the phone socket to get internet service. Check the RJ11 cable at the back of the router. You can try to use a different RJ 11 cable for isolation or try to use the cable that you are using at the back of your phone. You can also check if you are getting a dial tone on the phone as well.
thanks and kindly rate this post
Jan 03, 2012 | Belkin Play N600 Wireless Dual Band Router...
I have a Belkin N600 HD (FD78301). It was working fine but after few weeks the light turned orange from green. I started having intermittent problems accessing the internet. The router has the...
Hi jaijeetc, There is no need to worry about a hardware problem. The orange light is just telling you that you didn't have an internet connection. So no, there is no need to worry about a hardware problem. Cheers, Alex
Jun 02, 2011 | Belkin Play N600 Wireless Dual Band Router...
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
Idea of Belkin router is blinking orange is simple but there can be many more reason behind that light code .
It just can be ISP issue (may be internet service provider is down )
you might want to restart the modem than router and wait for like 1 min this Belkin router blinking orange to green.
For more details kindly visit
Belkin router blinking orange FIX belkin router amber light Issue
Good luck.........
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
Belkin Play N600 Wireless Dual Band Router (722868807453) Logo
383 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
