Question about Mitsubishi TS-4545 45" Rear Projection Television
Mitsubishi Projection TV Model TS 4573 not TS 4545
I seem to have a dead spot about the size of a pencil eraser in the lower left section of the scren. The screen appears to be made of plastic and there seems to be a spot where the coating on the inside of the screen is missing. Can this be repaired by removing the screen and touching up the coating from the inside?
  • Jethroe May 11, 2010
    Is there away to line the groves back to have them refract the light better or is there some type of refractive coating that has been knocked off there replacement is the only way?
    President:
  • 3,130 Answers
No if the problem is the screen, you will need to replace the entire screen assembly. some screens come in two parts. The inside of the screen is called the freznal lens, the outside of the screen is called the lenticular lens. Good Luck
Posted on Jun 05, 2007
LG 55 inch tv vertical lines, ive replaced the t-con board and cleaned the ribbons with use of an eraser and the lines continue, what is next thing to check?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 03, 2016 | LG Televison & Video
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
When turned on screen immediately goes to TOUCH DOT. This moves all over the scren. It was suggested that I hold down upper left screen, turn on unit and use a pencil eraser to toucht THE DOT. This...
If the unit does not work as described in the instructions, does not work as other similar examples do, I suggest you assume it is faulty and if it is under warranty return it to the supplier.
If it is out of warranty it would be worth contacting the manufacturer as they might offer an exchange service or fixed price repair or otherwise be able to offer you advice.
Sep 03, 2017 | GPS
White spots on my screen
Seems like a dead pixel in the display. The only way to fix it is to buy a new screen which could be more than the TV itself or just buy a new tv.
Dec 30, 2012 | Mitsubishi WD-73734 73" Television
Yellow spot on sony tv screen
not much you can to it sounds like some magnetic force was next to it IE speakers
Aug 18, 2012 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Please how do I refill my Bic Quantech #2 0.5 pencil? I have the correct size leads, but cannot figure out the mechanics. Thanking you, Margaret
Got it, thanks to the chap at OfficeWorks. Take the plastic cover off the eraser at the top of the pencil. Then wiggle the eraser out of its seat. Then you will find a hole going down the centre of the pencil, under where the eraser was. Drop a couple of leads into there, put the eraser back in, put the eraser cover on and Bob's your Uncle.
Cheers
Aug 29, 2011 | BIC Quantech Mechanical Pencil,...
My grandson spilled some water which got into my mitsibishi tv and created a black spot in the lower left hand corner. How can i fix this?
Take it apart and clean the dried water spots off. Its hard to say if it will work but that's the first thing I would try.
Jul 30, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How do you load a new lead?
To load more lead into the Zebra Z Grip mechanical pencil you must follow these steps:
1. Use the extra provided lead or purchase a refill package in 0.7mm size. 2. Remove the plastic cap that covers the eraser on the end of the pencil. 3. With the cap removed, gently tug the eraser out of the end. 4. When the eraser is removed, place a few pieces of lead into the open tube. 5. Insert the eraser. 6. Replace the cap on the end of the pencil. 7. Depress the end of the pencil a few times to feed the lead through the tip. 8. Write!
Mar 10, 2011 | Zebra Z Grip Mechanical Pencil, 0.7mm...
Televison & Video Logo
159 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
