Question about JVC AM FM CD DET FACE CAR STEREO
Radio will not work when i start engine but will when key is turned on
When key is turned on motor not running it works but as soon as i turn key to start motor it wont work..
    Problem Solver:
  • 12 Answers
Does your car have a factory amp in it? If so then it needs a delay to the power wire because it is going into protection. Also could be the your holding the switch to long trying to start the car.
Posted on Nov 25, 2012
2000 chrysler cirrus only starts with jump.all lights radio windows work plus engine gets hot fast
Have one of the auto parts places check your battery. Most do it for free. Your battery can be weak and able to run the car but not have enough amperage to turn the starter motor to get it started. The battery will eventually die and soon.
Aug 21, 2015 | Chrysler Cars & Trucks
How do I rest oil change light on a 2001 1500 silveradeo?
Place a piece of black electrical tape over it ,problem solved .you know the oil is good
Oct 10, 2014 | 2001 Chevrolet Silverado 1500
Suzuki Vitara 2007
The battery terminal connections is loose or corroded.
Battery faulty or discharged, if the cable are clean and tight on the battery turn the key to the ON position and switch the headlights or windshield wipers. If they won't run then the battery is discharged.
Broken, loose or disconnected wires in the starting circuit.
Starter motor pinion jammed in flywheel ring gear.
Starter solenoid faulty, Starter motor faulty, Ignition switch faulty.
Nov 23, 2013 | Suzuki Cars & Trucks
2001 Chev Malibu. Turn key on to start car, won't start. No warning lights on no lights on gauge panel. Radio works, dome light work.
check the ground leg to your engine.. it runs off the neg. battery terminal. will connect to frame and engine.. pull it off, wire brush it put it back.. you radio will work, 'cause it draws much less current, and is grounded in dash.
Jan 11, 2013 | 2001 Chevrolet Malibu
Starter motor not turning over when key is turned
Have a mechanic look but it sounds like the bendix which spins the starter is bad, usually if bad exactly what you are describing. When you try to start it engages and in a lot of cases if just a click and then will work at other times it is the problem---If the starter has been there for a while replace it and the bendix which almost always come as a unit.
Dec 16, 2012 | Mercedes-Benz Mercedes slk 230 kompressor...
Engine dosen't turn over when key is turned,even though lights,radio,&heater fan works
The fault could be a faulty starter solenoid or a faulty started motor or worn statrer motor brushes.
Jan 14, 2012 | 2004 Buick LeSabre
Turn the key back dome lights and radio work when doors are shut and not started but as soon as you open the door or start the car they do not work. the car is a 2000 catera. I think I need a k134 multi...
so you start the car and the radio will not work? but the radio works with he door open and key off? its normal to turn the car off and the radio play until you open the door.
Nov 24, 2010 | 2000 Cadillac Catera
When i try to start the engine a light on the dash comes on and says check engine i've checked what i can but i cant seem to find the problem and when i turn the key theres nothing at all happening...
It sounds like your starter has stopped working. I could be a bad fuse able link but this is usually a problem on older vehicles. The service engine soon light should always come on when you start the car. If you turn the key to start and you hear absolutely nothing then odds are its the starter. If you take it out yourself, you can have it tested at a local parts store before you drop the cash to buy another. I hope this helps!
Oct 06, 2010 | Hyundai Motor 1993 Excel
79 F150 won't start
try jumping across solenoid(touch 2 big posts w/a screw driver) check for a good ground between sol. housing and fender
Jul 01, 2009 | 1981 Ford F 150
JVC AM FM CD DET FACE CAR STEREO Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
