Probably no circuit for the crank sensor from wires not connected or the cam position sensors not connected
possible that the immobilizer is activated from a disconnected battery
do a compression test because if you fitted the heads then turned the camshafts over to get the valve timing before backing the valve adjustment right off you will again have bent valves
SOURCE: car dies when driving,check engine light comes on.
There is a good chance it could be your fuel pump , however if the check engine light is coming on and the dealer cant tell you what is wrong , try a different dealer or another shop. Second opinions never hurt.
SOURCE: ENGINE WONT TURN OVER
sounds like the timing belt it has a interference engine so if the timing belt broke you could have bent rods and cracked pistons or worse. good luck
SOURCE: I have a 2000 vw beetle 2.0 with no compression,
you may need to go back and check that your belt was installed correctly. it could be out several degrees.
I had a valve job and the timing marks are right on the money, It just has no spark i had spark before i took it apart and i know eveything is connected
OK i figured out what happen? when i was removing the heads you have to disconnect everything well the wire on the crankshaft position sensor was real hard do to heat and broke the wire shorted out thats why i had no spark....
