The water has not drained after cycle. What do I do?
Moon
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 05, 2012
Why is water leaking from moon roof
There is normally a small hose that drains the moon roof. Check to see if it is not plugged. It often will drain down along the drivers side post. Quite possibly plugged with dirt.
May 01, 2014 | 2007 Suzuki XL-7
How do i fix a leak in the trunk of my hyundai coming from the moon roof
there is hose going from each corner of the sunroof the rear 2 drain towards the trunk and should drain out the bottom of the rear quarter panels make sure the hoses are going where they should go
Sep 23, 2012 | Cars & Trucks
Water seems to be coming from underneath
Check that your drain hose is fully inserted into the wall/floor drain. then run an empty load with just water and watch it during the drain cycle to see if either the drain is backing up or if it's not fully connected at the back of the washer. if the drain is backing up you can try a drain sn ake available at most hardware stores and that will most likely clear it. If it's leaking at the connection at the back of the washer try to push it in fully or replace the hose altogether. It's not the water inlets because they always have pressure on them and would leak constantly. or you could have a cracked basket in which case you will be better to buy a new machine. cracked baskets don't happen very often though. And once in a blue moon it could be an off balance issue where its actually splashing out. Either way you need to spend some quality time with your washer and see why it's crying =]
May 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Water accumulates on the front and rear driverside floor boards
do you have a moon roof. That would be the only thing with drains.
Look for water stains, trails. Could be roof ditch moldings or even sealer skips in windshield or back window. Could b a/c drain if you are running a/c
Jan 08, 2010 | Saturn L300 Cars & Trucks
Half moon cubes too large. Intermittent harvest.
Counter clockwise should decrease it. Just turn it 1/4 turn each time and check it after it makes another batch of ice. Then reread this post and do it again till it's the way you want it.
Jun 30, 2009 | Whirlpool EL05CCX 4.3 Cu. Ft. Compact...
Where is the water drain plug for a 2006 hyundai sonata?
Does this vehicle have a Sun/Moon Roof? The 'water pan' as you call it, is not equipped with a 'plug.' It's part of the Sun/Moon roof assy. the problem is most likely the drain tube (perhaps misrouted) from the roof to the outside of the vehicle (drain alley). The drain tubs are located behind the head-liner at 4 corners of the assy. Otherwise, the leak you describe is possibly being caused by a windshield leak.
Jun 25, 2009 | 2006 Hyundai Sonata
Rain water comes in the car from the top, or moon roof. Is it because the drains are clogged or what?
well the easy way to check is open the sun roof look from the top of the car inside the sunroof is there sitting water in the little drain areas around the sunroof if so the drain is not working... if no sitting water pour some water in see if it drains if it does drain it is prolly the seal isself so if the water drains fine then close the sun roof and spray it with a hose if it still leaks in prolly the seal...if its the drain hose you will have to trace it it useally runs down the a piller let me no what you find or have other questions
Mar 28, 2009 | 2000 Volkswagen Beetle
Moon roof trickle
Any leaks past the sun roof should be channeld to and down the drains.There are four drains.I would open the roof and pour some water in the track and make sure it all drains
Dec 04, 2008 | 2002 Toyota RAV4
1995 bonneville water problems
I had a similar (and maddening) problem with my 1994 Bonneville SSEI. Try the following!
First,check the roof drains from the moon roof. The drains on the Bonneville from 1992 until 1999 are often and easily plugged. This simple check can be properly accomplished by first opening the moon roof, secondly finding the front drains (usually near the four corners of the moon roof) and third using low pressure compressed air to "gently" clear them. After clearing, you can check proper drainage by the drains by pouring a bottle or two of water directly into the drains and then looking beneath the car for the water that was drained.
Secondly, check the quality of the drain hoses from the moonroof. You can find them by carefully removing the plastic covers on each side of the the inside windshield pillars. Check out the hoses for proper connection and that they remain in good shape. The moon roof drain hoses can sometimes become disconnected or even disintegrate with age to the point that they leak.
Third, check the door seals and make sure that they are properly functioning. This can usually be accomplished by making sure the seals are not torn and ascertaining if the seals are properly secured to the door jams with adhesive. If not, reinforce the adhesive with additional adhesive.
Aug 04, 2008 | 1995 Pontiac Bonneville
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
