Question about Innova Equus 3150 CanOBD2 ABS Diagnostic Tool
IHAVE THE INOVA 3150 SCAN TOOL ,ITS STUCK OR FROZEN ON THE SAME CODES FROM A CAR ISCANNED AWILE BACK . ITS BEEN 3 MONTHS BUT EVERY TIME I TRY TO PLUG IN IT READS THE SAME THING ON EVERY CAR. IS THERE
ITS BEEN 3 MONTHS BUT EVERY TIME I TRY TO PLUG IN IT READS THE SAME THING ON EVERY CAR. IS THERE A WAY TO RESET THE DEVICE, REMOVING THE BATTERIES DIDNT EVEN WORK.
Why is trans stuck in 3 lope mode with no codes?
life mode (like?)
lope? (LIMP?)
my guess, this is an automatic transmission question.
and is no longer shifting correctly , right?
no codes?, does that mean the silly dash display ?(its useless ! and just a toy)
or USING a real scan tool (yes, only this really works! )
how long, well (soon and now) , my guess is you are not using a real scan tool
so are blind to all codes. (for sure the speed sensor will be showing trans in wrong gear, for SURE)
use an innvova 3160 scan tool and see them all,
you can not diagnose cars, with out a scan tool (real)
sorry its not going to happen.. (unless wild luck happens ,rare)
if the trans sticks in 3rd gear.
the TCM would be in fact storing many fault error codes called DTCs. and this is what we call limphome mode.
if the transmission brain sees gross errors it has no recourse. it must limit gears. (should be obvious why)
(if not obvious, imagine going to 1st gear at 90 mph) bam!
rent a tool?
buy one?
barrow one?
or get car scanned at any shop on earth, all autoshops can do this.
All ASE shops for sure can.... all. do.
http://www.walmart.com/ip/Equus-3160-Innova-ABS-Professional-Diagnostic-Code-Scanner/14644662
have you checked transmission levels yet, using the book not guessing and overfilling like many do?
and check fuses?
Aug 02, 2015 | 2006 Jeep Grand Cherokee
High idle 1100 rpm when engage drive or reverse and engine go down when put back neutral or park
try to reset ur computer system by clearing the codes or resetting adaptives with a scan tool.. if not try disconnecting battery from car for few minutes. this should reset computer for a idle relearn
Jun 28, 2015 | Cars & Trucks
Instrument panel has frozen what could be the possible cause of this.
Check fuses for Steering control module and connections to back of Display, same thing happens on Volvos usually fuse or heatsink on display control IC gets hot due to heat paste drying out clean and replace if possible or seek service agent , An OBD reader may possibly show up fault so you need to get a scan of the DT faults your local garage will do this quite cheap for you.
Jun 18, 2015 | 2006 Holden Barina
1999 dodge ram 4x4 1500 doesnt shift on time with high revs stuck on 2
is the transmission failure lamp on?
as stated in the operators guide?
no matter, scan it, plug in the scan tool and scan it
see all those P07xx codes, those be tranny, (and others)
always scan first. and check all fuses 1st 1st.
Jun 28, 2014 | Dodge Cars & Trucks
Kia p0431, p0446, p0715
They are three separate issues.
Code 431 involves the O2 sensors and the catalytic converter, code 446 is for the evap vent control for the gas tank, and code 715 is for the input shaft speed sensor in the transaxle.
The engine temp and other factors would need to be checked for code 431, and the sensors would need to be tested for the other two codes.
Aug 11, 2012 | 2002 Kia Sedona
How do you reset the service engine light?
Locate the diagnostic connector. On the 1997 Nissan Maxima the connector is located in the OBD2 standardized location under the driver-side dash, slightly to the right of the steering column. With the ignition key in the "OFF" position, plug the connector of the scan tool into the diagnostic connector of the car. Turn the ignition key to the run position but do not start the engine unless instructed to by the scan tool.
Turn the scan tool on and select "Global OBD2" from the main menu. Select "Diagnostic Trouble Codes" from the first sub-menu, and then "Read Trouble Codes" from the second sub-menu. Write down all listed codes and their descriptions before erasing them. This will save time if you must perform additional diagnostics.
Press the back button on the scan tool until the second sub-menu is displayed, and select "Erase Codes" or "Clear Codes," depending on the manufacturer of the scan tool. A message will appear asking you to confirm your desire to erase the codes and other stored data. Select "Yes". The scan tool will alert you when the codes have been erased.
Test drive the vehicle to verify the repair is complete. The 1997 Nissan Maxima on-board computer will run a series of tests on the systems in the vehicle, including emission control devices. To complete these tests you must take two test drives that include a variety of driving conditions, with a 2-minute cool-down between each test drive. If the service engine soon light does not come back on during these two test drives, you have completed the repairs and the reset.
Oct 25, 2010 | 1997 Nissan Maxima
I have a 03 s10 chevy and the check engine light is on how do i get it to go off
you need a obd 2 scanner to erase codes but if you dont fix the problem it will come back on
Feb 05, 2010 | 2003 Chevrolet S-10
ABS light just came on, is it an easy fix. My abs warning light comes on often. It usually stays on until I restart the car, then it might stay off for days but will always relight. Often, I turn the...
The code scanner that you need is called ODBII code reader with ABS, and it works in the same way as the one that you connect to the car computer module (ECU) to read codes when the check engine light comes on, but the cheap ones that you can buy from $50 do not have the ABS brake scan function.
If the problem is the ABS, then it is often a wiring to abs problem, or a defective ABS control module, a scan reading is necessary to know what the problem is.
Below few examples of Code reader with ABS:
Equus 3150 Innova ABS + Professional CanOBD2 ...
$199.00 - Amazon.com
Cp9449 Brake Scan Abs Diagnostic Tool Obd2 ...
$219.67 - eBay
Equus 3160 Innova ABS + Professional CanOBD2 ... $259.99 - Amazon.com
CAN OBDII Code Reader with Multilingual Menu $49.99 - Harbor Freight Tools
Mar 24, 2009 | 2001 Chevrolet Blazer
VIzio channels won't change
press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
Innova Equus 3150 CanOBD2 ABS Diagnostic Tool Logo
121 people viewed this question
Top Innova Measuring Tools & Sensors Experts
ray gallant
Vuk B
Tom Chichester
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
