Question about ViewSonic N2751W 27 in. LCD Television
Viewsonic N2751w continues to cycle thru channels at startup
When I turn the set on either via remote or Power button in front of set, the channels continue to cycle. If I hold the Power button down, the set will stop at one channel. I usually then hold the Power button and press Menu. At that point the channel surfing will stop but the menu on screen will cycle for a while. After three or four minutes of the cycling, the picture stabilizes and the set is usable.
Unplugged the TV and removed and reinstalled each connection. Don't know why but it was enough to resolve the issue.
Posted on Jan 06, 2009
My viewsonic n2751w tv will not stop channeling down... have to put weight on top to stop
mmm sounds like a sticky channel switch on your tv itself. Spray some special stuff called Contact cleaner spray available at any electrical outlet or hobbyshop - its a little bit expensive but works great to clean motherboards and most other electrical equipment. Spray while the tv is off and press buttons in between sprays
Jan 14, 2015 | ViewSonic N2751W 27 in. LCD Television
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
My viewsonic keeps changing channels which makes it impossible to use. We've unplugged it and everything. once you power it on, thats all it does. it continueusly changes channels. please help
The first thing to try is to see if a button is stuck on the remote or on the TV.
Remove the batteries on the remote and see if that helps. If it fixes the problem, you'll need to replace the remote.
If that doesn't help, look close at the buttons on the TV to see if one is jammed on. If changing channels continually up, then check the channel up button on the TV, if down then check the down button.
Worst case, you might have to take the back off the TV and unplug the cable feeding the external button panel on the TV and only use the Remote (for safety, rememeber to unplug the TV while doing any work on it).
Nov 28, 2013 | ViewSonic N3235w 32" LCD TV
When I hit the menu button it rolls trough the menu and I cant stop it, same with Channels.. Thanks EricdB
there some problem in your remote chip board.
menu button may be touching some other on the remote circuit board. thats why it causing problem.
open your remote and adjust properly your rubber buttons on the remote circuit borad. handle it carefully.
if you like this kindly rate me
Oct 12, 2010 | ViewSonic N2751W 27 in. LCD Television
Toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Jun 10, 2008 | Toshiba 36A43 36" TV
Viewsonic remote RC00070P
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Jun 10, 2008 | Televison & Video
Viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Oct 18, 2007 | ViewSonic N2751W 27 in. LCD Television
ViewSonic N2751W 27 in. LCD Television Logo
174 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
