Question about Refrigerators
Viking VCSB 483 freezes foods in refigerator compartment
Local Viking authorized service performed maintenance, changed water filter. Tech thinks problem is what is probably a thermistor, located under a plastic cover on the left inside wall, top rear, and looking like an old-fashioned power transistor, but with only two male spade terminals. I checked its resistance and got 60K ohms cold, which dropped to under 40K as it warmed. Altitude here is 6300 ft.
icansurf
  • 72 Answers
SOURCE: The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Posted on Jul 11, 2007
SOURCE: GE Refrigerator Compressor Inop.
I found this post by searching on the capacitor number, JSU21X126AQC. My 2001 Kenmore refrigerator (don't have model# here) compressor didn't run, but I heard it hum for a few seconds and then a click. That's the Klixon overload doing its job. I measured resistance of the compressor leads same as original poster. This lead me to determine that the windings were not open or shorted. The wiring to the compressor also fed the condenser fan, and it was running, so power was at least all the way to the compressor.
What I did find was that the 12uF capacitor was only 4uF. My digital volt meter has a capacitor check range. This compressor circuit is a permanent split capacitor type. Without the proper capacitance, the compressor can't start. I replaced it with a 10uF, 220v AC capacitor I had, and now it runs fine. I wonder how many refrigerators are scrapped because of this inexpensive problem?
Posted on Jan 07, 2009
  • 531 Answers
SOURCE: refrig/freezer thermistor temp/resistance chart needed
by model# you can get it not all carry the same (temp)
Posted on Apr 07, 2009
freetek
  • 5568 Answers
SOURCE: my dometic 2652 refrigerator freezes everything
Your problem seems to be fairly common but you may find a solution on the website at the link below:
Dometic recall
I linked to that page because of the recall that affects your model and I suggest you read consider it before you worry any further about the problems you are having. You can link to their home page from the recall message.
Posted on Jan 03, 2010
Testimonial: "thank you for the information I linked to the home page as directed and found the thermistor resistance reading."
  • 111 Answers
SOURCE: water dripping inside back of top compartment
It looks as if your drain tube has stopped up and the water is finding the next easiest route. The drain tube runs from the freezer area, down the back of the fridge to the lower area near or on top of the compressor where it evaporates. Some food may have gotten stuck in the tube. If you can get to the back of the fridge and see the tube (it may be in the wall) you may be able to dislodge it. There also may be a place in the refrigerator where it drips from the freezer to a funnel in there. It depends. But that is normally what happens when the refrigerator goes into defrost. It fires up cow-rod coils in the freezer area and keeps the frost off the coils thats why they call it frost free. the water then runs down the tube. Start checking there first.
Posted on Feb 01, 2010
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
No water flowing into ice maker. Water coming out of filter inside refrigerator
The first thing to check is the filter. It may have become loosened during loading of groceries or damaged due to freezing or even age. You should not have to shut the water supply off to do this - but since water is leaking from that area, it might be a good idea to do so first, or place a pot under it. Remove the filter by twisting the housing - most housings have arrows to indicate direction to turn and to align for installation - usually not more than a 1/4 - 1/2 turn.
Once out, inspect the housing of the filter - look for cracks and damaged seals on the neck or of the filter. If any are found, replace the filter. The filter should be changed periodically and if this has been in service for more than 6 months to a year, it is due for a change out.
You could use a mirror to look at the filter holder - there shouldn't be anything foreign there - especially if the ice maker was working fine before this.
Reinstall if it looks OK, or install a new filter. The filter should twist in reverse of the way it came out. You should feel resistance to turning 1/2 way through the turn until it can not be turned any further. Do not force the filter as it will not form a better seal than the 1/4 - 1/2 turn required to fully seat.
A filter can crack open if subjected to temperatures 32 degrees and lower, as the water in the housing will freeze and expand resulting in cracks in the housing. Check the temperature of the fresh food compartment by placing a thermometer capable of reading these temperatures in a cup of water nearest the filter location. Allow a couple hours for the water to assume the temperature of the compartment. Typical fresh food compartments should be around 35 degrees F. Adjust as needed.
I hope this helps - good luck!
Jun 10, 2010 | Frigidaire FRS26KR4A Side by Side...
Water pressure is at a trickle in door dispenser on fridge. filter is clean and mounted properly.
Check the water reservoir in the rear of the fresh food compartment. It may be frozen. If so, there may be an issue with the "damper control assembly" (located in the upper left side of the fresh food compartment) that allows cold air from the freezer compartment into the fresh food compartment. This cold air works its way down to the reservoir (and perhaps other items) and freezes the water inside the reservoir, which disallows regular flow of water at your external dispenser.
Contact an appliance service company.
Feb 19, 2010 | Frigidaire FRS26H5AS Side by Side...
The meat and veggie compartments are freezing the food and our water dispenser just stopped working. Do we need to manually dethaw the refridgerator (Kenmoore side by side)?
check your thermostat controller, it might malfunctioning that why your refigerator neverautomatically turn off when it reaches the cooling point
Oct 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
THE FOOD IS FREEZING IN THE NON FREEZER SIDE OF SIDE BY SIDE
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Frigidaire FRS23KR4AQ Side by Side...
Fridge compartment is freezing food/milk etc
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Machine stopped running, its getting power but wont run.
I would take it back to your service tech or choose another. It may be something simple that needs replacement, like a new cord. (or . . .)
Also, before thinking of buying a new machine, I would get another opinion.
Feb 17, 2009 | Husqvarna Viking 1
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
FILTER CUP&HS CRACKED,WATER LINE FREEZE
are you setting the stat right? lower the number, higher the temp. lots of folks think its the other way round. set stat to 2 or 3 and should be about the right temp
Jun 21, 2007 | Frigidaire FRS26KR4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
