Question about HP LaserJet 3030 All-In-One Printer
Vista doesn't detect hp laserjet 3030 as usb device
How can I get MS Vista to detect the printer as USB device?
  • theisen_schm Jan 04, 2009
    thanks for this - I also reloaded vista but nothing changed. The printer isn't shown in the usb list, but under "IEEE 1284.4 devices"
    Scholar:
  • 30 Answers
I had the same problem with a different model of the HP 4-in-1 not being compatible with Windows Vista. I went on the HP website, entered the HP model # (be sure to put exactly what it says on the Unit itself) and they will provide you with a compatible download for Vista. Good Luck.
Posted on Jan 12, 2009
  • 122 Answers
I had the same problem my new dell wouldn't recognize my printer and its on a network had to print through my wifes computer i Reloaded windows vista got rid of all the dell **** and now its fine.see if your printer is set for default in control panel under printers see if you have usb ports in the control panel under devices. if the usb 's aren't dected the drivers are gone in the machine use the cd that came with your computerfor usb drivers you might have to do alittle configuring . vista is no walk in the park.
Posted on Jan 04, 2009
    President:
  • 8,637 Answers
6 - Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System. Additional software will be available soon. HP has a driver solution available for your product. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. Currently, a full-solution driver is not available for your product. However, we do have an alternative driver solution that you can conveniently find in Microsoft Windows Vista. This driver will enable your product's basic functions to work and can be used until the full driver solution is available. Full-solutions will be available as early as January 2007. HP expects to complete the certification process for applicable software by July 2007. Solutions will be posted as they become available. Click here to recieve e-mail updates from HP when a solution is available. HP aspires to provide the most up-to-date information on HP drivers and software. Please check back soon for updates.
NOTE: If your printer currently uses either a PCL5, PCL6 or PostScript XP driver you may download the current XP driver from HP to provide printing functionality. Windows Vista printing is very similar to Windows XP and most print drivers supported in XP environment for LaserJet printers may also work in the Windows Vista operating system.
I have a hp LaserJet 3030 and I have misplaced the disk and now I cannot scan. When I press scan to it says - not setup in computer and when I press start scan it says - Waiting for pc. Please help
Access the manufacturer's web-site: http://support.hp.com
Enter '3030' and select your printer.
Click 'Software Downloads'.
Select your Operating System (Mac? Vista? 7?)
Download the device-driver.
Install the device-driver.
Scan.
Jan 23, 2011 | HP LaserJet 3030 All-In-One Printer
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Toshiba satellite E100» laptop and HP laserjet 3030 printer
Check the HP website and see if there are Vista drivers for your model. If you installed them from the disk they're likely not compatible.
Apr 27, 2009 | Toshiba Computers & Internet
LASERJET 3030 PRINTS ONLY 1 COPY VISTA 64
Well go to file and click on Print... this will bring up a list of settings for your printer as well as the list of printers. There you should see a box that says number of copies.
Dec 03, 2008 | HP LaserJet 3030 All-In-One Printer
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
After installing my vista can print perfectly well on test printout
Advise from http://www.bebo.com/andythoo
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
HP laserjet 1100 won't print from Vista laptop
Which version of QuickBooks are you using? Anything older than 2008 will not work with vista.
Jul 08, 2008 | HP LaserJet 1100 Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Laserjet 3030 hp printer after the setup it doesnt recognize the printer
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Jan 11, 2008 | Brother MFC-5840CN All-In-One InkJet...
HP LaserJet 3030 All-In-One Printer Logo
1,095 people viewed this question
Ben Johnson
