Question about Bryant Westinghouse Bqc Quad Circuit Breaker
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
It is a 20/30 piggyback, that keeps tripping when furnace is running,also connects to my stove. Can I put a 30/40 amp in there.I believe the circuit box is only a 200 amphes.
  • Hippy_dd Sep 15, 2016
    ok after reading what you have said and the answer u got and just had to make another point. here Is a pic of the front of a book called ugly's book. this is what is called ohms law and it shows all the basic calculations. I did them on your furnace from the info I got.
    it goes like so: watts/volts=amps
    all breakers have to be rated at 80% of wire size. this means that for an easy calc your receptacles or outs would be on a 20 amp circuit so 20*.8=16 so the 20 amp breaker is suppose to trip at 16 amps. contact me for more help I can walk u thru it
  • 5,245 Answers
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-install-a-subpanel.html
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
Posted on Nov 05, 2012
  • 760 Answers
SOURCE: I have a Murray panel and Bryant circuit breakers.
It used to be you could never install more than 42 circuit breakers in a panel. If you have that many spaces you cannot install "twin" breakers in the panel. There is a rejection feature for this. Some panels will have a portion that allows twins in part of tha panel, but not all locations so you cannot exceed 42 breakers. You can sometimes tell by the legend that willshow a space divided on some positions and others not. There are many different brands that will "fit" into your panel (GE,Bryant,Murry,Arrrow Hart, Crouse Hinds, Siemens), but only use breakers listed to be used in your panel, or you will not have the protection intended. If it's 40 years old maybe it's time for an upgrade. Be careful in that panel and be aware of arc fault protection when working on engergized equipment.
Posted on Jun 30, 2010
  • 12650 Answers
SOURCE: I am visiting my mother in law. She has a circuit
what else is on circuit with microwave and as to grafted is that a hard wired hook up if so breaker may be to low depending on how old the unit is but before replacing it i would check microwave draw and find out if anything else is on circuit
Posted on Jan 25, 2010
  • 760 Answers
SOURCE: is bryant breakers ok in a murray box
Look on the label inside the door on the circuit breaker panel. It should list part numbers for acceptable breaker. The key is the part number. Bryant is now owned by Westinghouse. Murry is now owned by Siemens. While many breakers will fit in other brand panels, they are only code compliant if they are listed for that panel in which they are installed. Since names have changed go by the breaker numbers. If the breaker number you have is listed on the label then it would be ok. Breakers aren't that expensive, if you have doubt, go to your supply house that carries Siemens and buy breakers listed for your panel.
Posted on Jul 11, 2010
  • 760 Answers
SOURCE: We have a westinghouse box and it has a 200 amp
You should get the exact breaker number to be safe. Westinghouse is not Eaton. Here is one example.
http://www.acehardwaresuperstore.com/westinghouse-replacement-main-circuit-breaker-p-21528.html
There are many places online. 200A breakers rarely fail, unless loose connections on lugs (AL WIRE) cause overheating.
Posted on Aug 18, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: My old Bryant circuit breaker
Hello
The spring in the breaker is worn.Best to shut off main and disconnect breaker,pull out of box and take it to a electrical hardware store.
Home depot and lowes sell many different types.The numbers you gave match nothing i can find.
Posted on Mar 31, 2011
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Is there a less expensive replacement for westinghouse 200 amp main bj2200b
Following link shows $97.
https://www.acehardwareoutlet.com/ProductDetails.aspx?SKU=32247
20 years ago they sold main breakers for 100$.
Certainly buying a breaker is cheaper than installing entire new panel.
Sep 19, 2012 | Bryant /murray Bj2200 Main Circuit Breaker...
I need to replace a 15/15/15/15 Bryant Quad breaker. It is very difficult to find these for sale. Can a quad be replaced with two twins or four single pole breakers?
The reason for using the quad, is so that if any one of them trips, they all trip. GE used to sell lever covers that would join the levers together. I don't know if they still do. And I don't know if the Bryant breaker is JUST 4 single poles with their levers connected together.
Aug 13, 2011 | Bryant Westinghouse Bqc Quad Circuit...
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
We have a westinghouse box and it has a 200 amp main breaker, but we cannot find a 200 amp breaker anywhere. Do you have any idea where we can locate one??
Aug 14, 2010 | Bryant Westinghouse Bqc Quad Circuit...
Is bryant breakers ok in a murray box
Jul 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
Gas Furnace not working trips breaker
Does it trip the breaker when the safety switch is NOT pressed? I am trying to isolate where to look for the short circuit. Is it before the furnace, or after the furnace. If the breaker trips with the safety switch not depressed, the problem is not the furnace, and could be where power enters the furnace, or further upstream from the furnace.
Dec 13, 2009 | Ruud UBHC Air Conditioner
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
Bryant Westinghouse Bqc Quad Circuit Breaker Logo
409 people viewed this question
Top Bryant Electrical Supplies Experts
john h
Gene Haynes
Tom Chichester
Are you a Bryant Electrical Supply Expert? Answer questions, earn points and help others
