Question about Sewing Machines
Bernina 830 firmware error 03000
I have been trying to update the firmware on my bernina 830 and I get an error 03000, " No valid updates on USB stick" and " Notice: NG1 and NG2 have different update files." I downloaded the zipped firmware update and unzipped it with winrar and loaded it on the stick, where I confirmed its location. Help...
  • 16 Answers
SOURCE: Bernina Updates
a bernina technician would be able to check in service mode
Posted on Jun 28, 2008
  • 52 Answers
SOURCE: bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Bernina 830 stuck
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
  • 55 Answers
SOURCE: I have a bernina 830, I replaced the motor but
the 830 has 3 'banks' of terminals to connect to. with the motor in the cover and laying over on its side so you can see the motor and wiring, one motor wire goes to the teminal closest to the machine pulley and the other motor wire goes to the middle terminal.
scott
Posted on Jul 26, 2009
  • 8 Answers
SOURCE: bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
Posted on Sep 06, 2009
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
What buttons to press to open mechanics scree on bernina 830
Depends what you are trying to do. There are instructions in the owner's manual, ie calibration, setup, troubleshooting, etc.
http://www.bernina.com/en-US/Support-US/Machines/BERNINA-8-Series/BERNINA-830
Feb 11, 2016 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
Bernina Quilt Cad and Quilt motion says there is no USB connection
Hey,
I have been messing with this system for over a year when I can make it down to my grandma's house. Using a Bernina 830.
Last time it was taken into the shop the firmware was updated on the machine. Since this happened the quiltmotion software needed to be updated.
The usb cable also needs to go to the cradle usb B connection of the cradle to the usb a connection of the computer. The usb connection on the computer is a separate animal.
Hope this was helpful
Jun 26, 2012 | Sewing Machines
Bernina 180 with Firmware 2.08 - can it run DesignerPlus 5 or 6?
You will need to update the software in the machine, to a min of version 3.08 this can be done at BERNINA dealer (usually free of charge) once this is complete you designer will fully be compatible. WHEN YOU TAKE YOUR MACHINE IN TO BE UPDATE DO NOT FORGET TO TAKE THE EMBROIDERY UNIT IN AS WELL AS IT CONTAINS ITS OWN SOFTWARE
Mar 22, 2010 | Bernina Artista 180
BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Oct 03, 2009 | Bernina Sewing Machines
Sewing Machines Logo
133 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
