Question about Sony Playstation 3 (PS3) Console
PS3 Error code 80029020
Unable to connect to DNS. PS3 Connection error 80029020? Connection Test Completed Obtain IP Address Succeeded Internet Connection Succeeded Playstation Network Succeeded UPnP Available NAT Type Type 2 Connection Speed (Download)* 377.2 kbps Connection Speed (Upload)* 315.8 kbps * Connection Speed times are estimates and are provided as reference only My Mac address does not match the Mac address on my new router and the download and upload speeds do not match the good speeds I get from my laptop when running a speed test. A connection error has occurred.(80029020) EVERYTHING IS CORRECT, I HAVE TRIED FOR 2 days TO GET IT TO WORK! Please help me, Extra details; I have a new Virgin Super Hub router, that works fine for everything else, very fast. I have a 120gb PS3 anything else you need to know, please tell me and i will post it. Thank you
3 Suggested Answers
  • 3 Answers
SOURCE: dns error
First chek your cables to make sure they're tight. Then test the internet connection in the settings. Restart ps3 and it should restore internet connection. If not, Cable is not working or is damaged.
Posted on Aug 12, 2009
SpideRaY
  • 687 Answers
SOURCE: My PS3 is telling me that it
This sounds like you might need to open a port on your router or firewall to allow the PS3 to send info to the games specific server just because the PS3 has been given an IP address the PS3 still needs to connect through your router using NAT.
I suggest first turning off your Windows Firewall and your ISP firewall then into your router admin panel and open up the correct port then do the same on your firewalls.
Next, you need to enter these numbers for the PS3 to work.. so put these in the port start and end. 80 , 443 , 5223 , 10070 (start) and 10080 (end) , 3478 , 3479 , 3658 , 10070. They should be in both start and end except for the fourth which will have 10070 in start and 10080 in end.
The first 4 are TCP and the last 4 are UDP both types are required.
Posted on Feb 01, 2010
Hi I am having an error code 80029020 on my ps3 , does someone have any ideia what that means and what could I do to fix it ? thanks
If like me you already use a DMZ for your PS3 connection;
Try going to TIME AND DATE SETTINGS and update them "via internet"... Dont know why, but seemed to solve the problem
Feb 09, 2010 | Sony Playstation 3 (PS3) Console
My PS3 is telling me that it "succeeded" in obtaining my IP adress,but now its telling me that an error occured during communication with the server. This is a DNS error.(80710102ff), I Have tryed every...
Feb 01, 2010 | Sony Playstation 3 (PS3) Console
Dns error
Aug 12, 2009 | Sony PS3 40GB Best Sellers Bundle Console
System Update Troubles
you can contact ps3 tech support on Tel: 08705 99 88 77
I was talking to a courier driver the other day and he says that he has picked up no end of PS3s with errors
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
IP Adress Can't be Read By PS3
Well, I'm not completely sure how to help exactly. This problem sometimes prompts as "DNS" error followed by an error code. If it displays a DNS error, then your problem is that the PS3 cannot find the modem (and router if you have it connected that way).
DNS errors on the PS3 simply means that it cannot find (see) the modem/router.
One way of correcting this would be to reset your modem (and router if you have it connected that way)by unplugging it (from wall and power port). Keep it unplugged for 1 minute or so. Power down your PS3 at the same time.
Plug in your modem (and router if you have it connected that way) and allow for it to reset.
Now power on your PS3 and go to the network settings and establish a new wired connection. Follow the prompts and test the connection afterwards.
Mind you, this is a general means to solving the problem. Try this first to see if you are successful.
I do hope that this helps you.
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
Heeeellllllpppppp!
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
PS3 connection error
Are you connecting through a router?. If so set all of your PS3 settings to easy. If your trying to connect directly to a dsl or cable modem, you might not get connectivity but may get an ip address, as some providers require that you register your MAC address with them to connect a particular device. If you have a router...say a wired one, and you connect any PC through it and get internet, you should be able to hook up the PS3 and put it on easy automatic settings for the connection and it should connect. However, if the router is set for a static ip address (no dhcp), it wont hand out all of the information to the Ps3.
Jan 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
