Question about Emerson Lc320em1 TV
My emerson tv has a horizontal line through the screen
Unplugged the power and reconnected all other cables. still has the line on all input sources.
  • 127 Answers
Is that a flat Panel?If not you have a vertical output Problem.
Posted on Nov 05, 2012
Emerson EWF2004 has a horizontal line in the middle of screen some color can be seen the rest is black. I disconnected cable, unplugged tv line remains how can I fix it?
This sounds like an analog TV. If so, the vertical oscillator or vertical drive output needs to be fixed. You will need a schematic to do the job.
Feb 25, 2015 | Emerson EWF2004 20" TV
My Ultravision TV is now having horizontal lines. Do not know if it has a horizontal hold button hidden somewhere or is the TV going out? Can I fix it myself. Large screen
Can you try and see if it is your source that has the lines or the actuall TV that has the horizontal lines.
What is your source? Direct TV, Cable TV or even off air Digital TV.
If you remove your source do you still get the horizontal lines? If you do then what colors are they? Seems if when you remove your source input and you still have these H-lines then you have issues with your individual LCD palets. Especially if they are just Green, Red or Blue?
Nov 07, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Jvc lt-42pm30
Horizontal lines are usually caused by a bad LCD (screen)..
Sep 24, 2017 | JVC LT-42X579 42 in. LCD TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Screen shows several horizontal and vertical lines.
this can be in your video cable or LCD Connector issue. but most problem is in the flex cable of LCD. some other cases cannot be fix and replace new LCD Screen.
Aug 14, 2009 | Samsung HP-S4253 Television
My smamsung lcd tv has thick horizontal lines across screen that move upward, any ideas?
You have what we call 60 Cycle Hum Bar. You also might have audio hum too. The problem is a grounding issue either coming from the source such as a Cable Box or a Sat box. More often this occurs with cable boxes. First unplug the source box from the tv completely. You will find that the Lines have disappeared. Next connect a Coax cable coming from the wall bypassing the Box to the RF input on the tv. If you still have the Lines, then the problem is with the Cable signal not being correctly grounded and you need to call the Cable co.. The Cable box can also be causing this as well. If all of this does not work then try using another set of Component cables as they can cause the same issue.
Jul 09, 2009 | Televison & Video
Seeing blue screen only on all chanels/Inputs but hear sound
Sounds like trouble in blue video amplifier or shorted picture tube; needs to be looked ats by TV tech.
Jul 16, 2008 | Emerson EWF2004 20" TV
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Emerson Lc320em1 TV Logo
350 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
