Question about Craftsman Air Tools & Compressors
Model #919165020 somtimes it will run sometimes it won't
Will run and compress air then somtimes won't kick in and compress air
2 Suggested Answers
dleemacc
  • 281 Answers
SOURCE: I am replacing the cylinder
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919165020/0247/0703000 This is the exploded view that I used.
67 head 65 gasket 64 reed valve plate 63 ring,this one goes under the reed valve plate 62 screw that goes thru the 61 piston 60is a ring that sets on the top of the connecting rod screw the piston with the ring into the top of the connecting rod then take the connecting rod end cap off and cover the studs with some rubber tubing.This will protect the crankshaft when you push connecting rod and piston assembly in to the sleeve that is seated in the block.The ring should be flexible enough to push into the sleeve,if not a bit of oil should help.Guide the connecting rod on to the the crank shaft.I hope this helps and thank you for using FixYa.com
Owner's Manual - CRAFTSMAN Air compressor 919165020, 919165050, 919165090, 919165230, 919167330, 919165221, 919165070, 919165310, 919164200, 919165060, 919165300, 919152922, 919165250, 919186430, 919155613, 919164150, 919165030, 919165130, 919165500, MG2-OILFREE, 919165110, 919167200, 919165000 - ManageMyLife.com
Posted on May 14, 2011
No compression, decompression jammed
Valves could be sticking closed or open causing (good or bad compression) that or de-com-lever if faulty somehow.. And you need to do a compression test
Oct 04, 2014 | 2004 Yamaha WR 450 F
Have oc60 diesel eng runs for a while then drops in revs sometime picks back up somtimes stalls then restart
Possible low coolant in AC unit. Sounds like the comressor (A/C) is putting a load on the engine when the the coolant is returning to be compressed after it becomes saturated. Possible air dryer or A/C condensor problem, also.
Apr 17, 2014 | Garden
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
1997 rm 125 won't start why should I do?
For your dirt bike to run you need 3 things:
1. Fuel (gas/air)
2. Compression
3. Spark
Start trouble shooting through these. Make sure your gas is turned on, and that it flows through the carb; if you tilt the bike does fuel run through the overflow tube in the carb? Make sure you have good spark; take out the spark plug from the cylinder, still connected to the ignition wire touch the threaded end to somewhere metal on the engine and turn the bike over. You should see a spark. Finally, do you have good compression, how hard is it to kick over etc.
These are the first things to trouble shoot, I would look on youtube if you don't know what you're doing, there are plenty of helpful videos there. You can also try putting a thimble full of fuel into the cylinder and then kick it over to help it start if it has been sitting a while.
Dec 09, 2012 | Motorcycles
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Why won't my compressor stay running
Does it run at a low speed to start but then just quits, or goes back to low speed? Some compressors have a starting winding in the motor to get it running, then as it speeds up it kicks out the starting winding and goes to the normal run winding. I am thinking that the run winding may be bad. Or else you have a bad contact in the pressure switch and the compressor kicks on but the contact arcs and loses connection sometimes. The difference would be if the motors always does the same thing in about the same time it would be the motor problem. But is the compressor runs and then all of a sudden stops, sometimes in a minute, sometimes five minutes, I would look at the pressure switch.
Apr 23, 2012 | Air Tools & Compressors
Quad wont start got spark got fuel and got compression
If it's a 2 stroke you have a crank seal out. It can have compression but won't have vacuum, and it won't run. Sometimes the seal can be replaced on the magneto side without splitting the cases, but I'd rebuild the entire motor and replace the crank bearings along with the seals. Good luck!
Jun 07, 2011 | Cobra Snake Furious Motorcycles
Replaced a/c compresser. installed new one. compresser won't kick on so i can continue to add the freon.
Hi are you running the air on high while charging it, and some times you have to wiggle and jiggle the charging hose fitting to get it to take.
Jun 05, 2011 | Ford Explorer Cars & Trucks
I am replacing the cylinder sleeve and compression ring on my Craftsman air compressor model 919165020. Searspartsdirect says that I need two compression rings. Is this right? My compressor only had one...
May 14, 2011 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
52 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
