Question about Hoover V1 SteamVac SpinScrub Vacuum
High pitch grinding noise
Borrowed it from a friend that got it at a pawn shop.... When we turned it on it was amazing all of the nasty water from the carpet. Well when after about 3mins. it started to make a high pitched grinding noise and the brushes will not move. I have taken it apart and the motor still turns on and works. The gears that move the brushes are still good and no broken tooths. Any one have any I ideas??
  • 3,085 Answers
My bissell quicksteamer makes a high pitch squeal
Something is caught in your beater bar , causing preasure on another part of machine. This contact is the cause of the noise. GOOD LUCK FRIEND.
Sep 16, 2014 | Vacuums
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
I have a Napoleon Pellet stove insert Model NPI40. When the fire burn rate is extremely low it seems to operate normally. However, when I turn the heat up even a little I eventually get a high pitched...
my theory is based upon 1st hand knowledge with a newer EPA compliant freestanding wood burner, with the air-tight and high efficiency ratings.
its possible that its just the high rate of air moving through the air chambers , similar to a organ pipe.
give it some thought
Nov 03, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
High pitched noise
High pitched noise usally happens when the suction pancake fan fins become loose on the shaft.Usallythere is two or more sandwiched on the motorshaft .. Matter of taking the tin split casing apart and check and tighten :^/
May 11, 2009 | Bissell 3750 Lift Off Bagless Upright...
High pitched noise
It sounds like you may have a bearing problem. The motor bearing eventually gets damaged by the water vapor that is drawn in by the fan. This will cause a high pitch squeel from the motor. It is possible to replace the bearing, but it should be addressed by a professional techician.
Jan 27, 2008 | Hoover F5886-900 Steam Vacuum
High pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
May 23, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover V1 SteamVac SpinScrub Vacuum Logo
210 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
