When I turn the key to the on position, and then start my Mitshubishi it won't start
All of the panel lights come on, but it won't turn over. Whats the problem?
  • Tony Nov 05, 2012
    Television or you car?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I am fairly sure this is a car question--you might want to post a new one with year and model in the car area on this site.
Posted on Nov 05, 2012
2005 ford 500, won't start a lock light is
need to reprogram ignition key security system when battery disconnected. turn ignition key to the on position for 3 to 10 seconds until the lock light goes out then start vechicle.if lock light dont turn off turn ignition switch to on position 30 seconds until lock light turn off.
Jun 12, 2013 | Cars & Trucks
HD Dyna 2010 Superglide won't start
Hi Clements_car, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Mar 25, 2013 | 2010 Harley Davidson FXDC Dyna Super Glide...
My security failed light keeps coming on in my 2002 Jaguar and won't start. What can I do?
hook up battery charger on low amp charge, turn key to run position and leave it on for 20-30 min. then turn key off, wait a few seconds, then attempt to start. if that dosent work, let me know.
Feb 14, 2013 | Cars & Trucks
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
How can I get key out which is stuck in ignition of 2008 cobalt. It also won't start
This can happen if the battery is low / dead. To solve, connect a set of jumper cables between the battery in the Cobalt and a running car's battery. Shut off the running car. In the Cobalt, make sure all accessories (lights, radio, fan, etc.) are off. Step on the brake, then move the gear shifter fully into the PARK position. Next, either attempt to start the engine, or turn the key to the OFF position and remove it from the ignition.
I hope this helps & good luck!
Jan 03, 2013 | 2008 Chevrolet Cobalt LS
2000 model Hyundai lantra immobilizer won't start
un hook your battery for 15 minutes then retry to start
Jan 17, 2018 | 2000 Hyundai Elantra
CAR WON'T START AFTER CHANGING BATTERY
it is in theft mode. you will need to turn the ignition to the run position and the theft light will blink. leave on for about 15 min. turn key off then turn back to run position without trying to start it. leave in run position fo another 15 min. turn off then try to start. should start
Jun 13, 2012 | 2005 Saturn ION
The 'theft system' light does not turn off with the key in the run position on my 1999 chevy cavalier. car won't start, it won't even crank over. the battery and the starter are brand
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
Mar 18, 2012 | 1998 Chevrolet Cavalier
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
