Question about Saws
! have a metal cutting bandsaw from toolmac model 73- 532501 Where can i get spare blades
    Sergeant:
  • 468 Answers
One question , what happened to your blade? Why do you need spare blades? Oh ,actually,t here are lots of sites that can supply some blades for your bandsaw. Give it a try visiting sawblade.com .
Posted on Nov 07, 2012
  • Peter Michael Adamczyk Nov 09, 2012
    When i bought the bandsaw the blade was blunt now i have one thanks to you
  • Jack Faire Nov 09, 2012
    No problem Peter. Where did you get your new blades? Did you try checking with sawblade.com?
  • 3 Answers
SOURCE: Sears 12 in bandsaw vibrates when cutting
Are you sure the wheel bearrings are in good shape, and are all the screwws in the drive pulleys tight,including the pulley set screws.
Posted on Dec 28, 2008
efs_perpends
  • 1996 Answers
SOURCE: When making a straight cut with my bandsaw, the blade will
Before tuning it up, loosen the guides and wheels away and square the table to the tensioned blade. Then follow these steps in order:
  1. First, adjust the upper wheel so the blade is tracking at the center or just to the front of center of the wheel tire. (You can see this with the cover removed, and adjust it with the nut/wing nut in the back).
  2. Now, make sure the blade guides are adjusted so they don't deflect the blade to either side (when looked at from the front), so they contact the blade just behind the gullet of the teeth, but not against the hooked teeth themselves, and are just tight enough to allow the blade to run freely (including the weld). (If your guides are worn and out of flat, you may wish to dress them on a sander before adjusting them against the blade.) Adjust the guides both above and below the table. At this point, ensure that the guide bar moves up and down easily and locks into position without torqueing the guides against the blade.
  3. Finally, adjust the bearings behind the blade, so they just kiss it, and turn freely when you revolve the bandsaw wheel. They will support the back of the blade when pressure is applied against it during a cut, and help immensely to keep the blade tracking straight.
At this point, check the cut by trying to follow a straght line penciled on a board. Some blades will naturally tend to veer slightly on a diagonal, depending on how they are sharpened, and you may have to adjust your fence to compensate for this "drift".
But if you follow the steps outlined above, and have a good sharp blade to begin with, you should be able to split a line.
If you follow these tips and they prove helpful, please let us know your problem is solved. Otherwise, give us a little more detail and someone will be happy to follow up.
Posted on Mar 25, 2009
  • 11 Answers
SOURCE: Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Posted on Jun 26, 2009
How do I get a manual for a trade master 9 bandsaw?
MODEL: 270S INSTRUCTION MANUAL - Industrial Tool ...
www.industrialtool.com.au/.../user_manuals/trademaster/RF270S.pdf
SHUT- OFF power and clean the BAND SAW and work area before leaving the machine. (11). ... Consult the owner's manual for recommended accessories.
Trademaster bandsaw manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesDake parma trademaster section i ii band saw instructions parts. Dake parmatrademaster, section i ii, band saw, instructions and. Vertical bandsaws ...
Trademaster RF 270S Instruction Manual - ManualsLib
www.manualslib.com > Brands > Trademaster Manuals > Saw > RF 270S
View and Download Trademaster RF 270S instruction manual online. METAL CUTTING BAND SAW MACHINE. RF 270S Saw pdf manual download.
[PDF]Trademaster Parts Manual - Utilimaster
Jan 21, 2016 | Blade Saws
Can anyone tell me if there is a replace blade for clarke bandsaw model tb1015a
I get my blades on sawblade.com. I am using bi metal blade for cutting structurals and beam and hard back blade for cutting wood.
Oct 28, 2014 | Saws
Where do I get a blade for Pro Tek 10" model 3104
I buy mine on sawblade.com ; they are cutting blade stock to any length. Your bandsaw is using 62" right? Try to use a 1/4" 0.025 6 TPI flex back carbon blade for cutting non ferrous metals.
Jul 04, 2014 | Saws
Mbs45 blade undercuts out of square, twist in 2x2 1/8" tubing
I believe Black bull band saw is a Taiwan imported saw. They are even cheaper to HF band saws. This band saw have so many issues; make sure you align the guides, tune it up and use good bi metal band saw blades. I suggest you use the Haltbar 601 bi metal blade. I'm using Haltbar and I'm getting really nice cut.
Jun 18, 2014 | Buffalo Tools Black Bull Metal Cutting...
Bs2206 bandsaw blade
I have a 14" band saw. I also do metal cutting on my 7x12 band saw and get my blades on sawblade.com . They custom weld blade to any length.
May 10, 2014 | Saws
I'm looking for replacement bandsaw blades for a McGraw-Edison 10" Bandsaw, M/N - T6760. Any Ideas?
I have 11[6 tooth scrolling blades] & 3[3/8" 14 tooth general purpose metal cutting blades.T8380-16 & T8382-16 for McGraw Edison 10" bandsaw. blades are 57" been hanging in my garage for past 25 yrs lol. would like to sell to best offer. contact me at tazzdh1959@yahoo.com
Feb 24, 2011 | Saws
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
7. close the covers
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
I cannot get the blade to track correctly on my JET 12" band saw. What could be wrong? I have done exactly what the manual says to do. I am not sure the square box on the outside is fitting. The little arm...
i love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for bette adjustment and protect teeth on the band.
start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock it in.
4. repeat previous operation on external guide block and after you slide paper out, lock it in position.
7. close the covers
8. adjust hight of the guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
this general rule applies to all bandsaw, regardless of brand, make, vintage. do remember that this is not a toy, it will cut through, wood, metal and your fingers...
do remember, that these operations must be performed every time when you change the blade, to not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, use protection screen and googles, you have only two eyes and there are no spares...
Jul 30, 2010 | Jet JWBS-16B 708749B 16-inch Bandsaw
MBS 240/E proxxon bandsaw
the 24 TPI is the one to use. It sounds as if the blade is running to fast and over heating the blade and causing it to lose the temper in the balde steel. Try slowing the blade speed down if you can. Also you can try putting some cutting oil on the balde to stop it from clogging up. You can also rig up a small air line to blow on the cutting area to cool it down and remove the metal chips. I've also applied some wax to the blade every so often. A candle will work for this too. Hope this helps you, Jeepfxr
Jan 10, 2010 | Proxxon 28174 24-Tpi Fine Toothed Band Saw...
Saws Logo
146 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
