My hisense 32 in hdtv iv had for almost a year has worked totally fine, than today we moved it to a diffrent spot in the room turned it and cable box on for bout 15 mins and come back in room after wiping it down with a paper towl with windex sparayed on towl and it is off and will not turn on or no lights nothing or remote tried fuses n plugs everything on cable box works just not the tv no power. Is there anything I can try or see to do why would out of no where it just die like this! Makes no sense! Help
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Check to see no master power button on rear, other than the cord not being in all the way the set would have to be opened to see if a bad fuse or not......
Posted on Nov 05, 2012
5 Suggested Answers
  • 22 Answers
SOURCE: My 32' Magnavox LCD TV won't turn on
it sounds like the internal fuse blew out it normaly a 5 to 15 amp fuse the you can pick up at any auto parts store if you are in the philladelphia area i have someone who can come fix it for you
Posted on Dec 02, 2008
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
  • 73 Answers
SOURCE: the tv will not turn on anymore-have a blinking
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Posted on Jan 21, 2010
Raditronic
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Using cable remote when box is in another room
The IR detector of the remote will work only with a direct visual contact. hence it si important that the cable box must be located in the same room so as the remote works perfectly.
The remote might work with a deflection by it might not be a good solution.
You can move the cable box to the position of the TV so that it works well.
Nov 19, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
Today was the HD switch..I get nothing on my HDTV?
This wound be due to a bad tuner and nothing else. Speacially with those pop's in the audioCheck and see if your still under warrentee if not give www.teexp.com a try they will work with the manufacture so you can get some of the cost down in the repair. Now OTA signals is diffrent then cable/sat so please check and make sure when your scanning for OTA that its see on antenna if it is and your still hearing pop's the tuner is gone.
Jun 12, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Tv flashes when changing channel on sky hd box
Hi I have the same problem I got my TV replaced just today got brand new even better model. and guess the problem is still there.it's not individual,it must be in the whole series. if you have a solution mail at hajjid@yahoo.co.uk
Mar 26, 2009 | Hisense LHD3204US 32 in. LCD HDTV
Moving TV's from one room to another
tSounds like you have a PIP window open. Is everything else black excpet for that small "internet box?"
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
