Question about Orange Sydney - Black Smartphone Wi-fi , 3.2 Mp Camera ,touch Screen
Orange sydney touch screen
Touch screen not working done a recalibration more than once some parts of the screen work but are slow to work
How do you recalibrate the screen of a tomtom go 750
Pls factory reset the device and calibrate the touch with its first boot.
Regards:Himanshu
Aug 28, 2012 | Tomtom GO 750 LIVE GPS Receiver
Why em808vid touch pad is not response?
I've similar question. My ipod touch 2 screen is very finicky! It sometime responds just fine, but other times requires multiple taps before it does it's duty. Is there a fix for this? I have tried soft resets and recalibrating. The recalibration works fine, but I don't think it should have to be done daily which is about what I'm doing now. Is there another more permanent fix for this problem?
Aug 13, 2012 | Ematic 8GB Flash MP3 Player EM808VID with...
I am looking for a repair manual.. Does anyone have one in digital format?? 2.5 yo Nuvi 680 na touch screen stoped working. matbe a bad connecton.. I cant get it open there are only 2 screws I can see...
If the Touch Screen isnt working, have you tried to recalibrate the screen?
Turn off the Nuvi and then back on.
Slide Power key to the right (lock )
Hold your finger on the screen for about 30 seconds untilthe calibration screen appears.
Follow the on-screen instructions...
Also the 2 screws you took off once you done that you would have to use a plastic pry tool to lift cover up
Oct 26, 2010 | Garmin Nuvi 680 GPS Receiver
How do you recalibrate the touch screen on the Quantum XL-1000?
Enter service mode....
Press the start/stop switch and hold it while you power the machine on.
THEN, press the reverse switch, hold it and press the lcd. Release the reverse switch AFTER you touch the LCD.
Nov 15, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Touch screen not responsive Garmin 680
The cable to the touch sensitive part of the screen may have come loose (easily happens if knocked).
Try taking the unit apart (with care and the right type of screwdriver) and reseating the connector cable.
Once you've done this you may need to recalibrate the screen. Holding the power switch down will get you to the reboot / recalibrate screen.
But of course this will probably invalidate your warranty so beware.
Nov 04, 2009 | Garmin Nuvi 680 GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Does not respond to stylus
Try recalibrating the touch screen. Devices with touch screens need to be recalibrated in order to respond properly. The greater the use, the more often recalibration is necessary. I recalibrate my phone once a week. I hope this helps.
May 22, 2009 | Palm Treo 755p Smartphone
Try recalibrating the touch feature. Touch screen devices need to be recalibrated ever so often. The more it is used, the more often recalibration should be done. I recalibrate my LG VU once a week. Hope this helps.
May 22, 2009 | LG KU990 Viewty
Orange Sydney - Black Smartphone Wi-fi , 3.2 Mp Camera ,touch Screen Logo
62 people viewed this question
Top Orange Cell Phones Experts
Computer Repairing
Computer Repairing
matt
matt
Are you an Orange Cell Phone Expert? Answer questions, earn points and help others
