Question about Panasonic PT-51HX41 51" Rear Projection Television
TV suddenly blanked (power is not off)
This TV suddenly blanked out - no sound or picture. It smelled like burning wires. There is a faint humming sound but nothing else except possibly a VERY faint yellow couple of lines on the bottom. ANy ideas? THis TV is 5.5 years old.
It is probably a burning deflection yoke.I just fixed an identical model with the same condition,Jim
Posted on Jul 22, 2007
SOURCE:
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
F&P dishwasher DW60CDX1 (5yrs old) which will drain then fill but will not start the wash cycle. No error codes just a humming sound, possibly faint electrical burning smell (turned off quickly in
We just had this problem, the dishwasher filling, then humming with a slight burning smell. It would drain ok if turned off then on again. It was the capacitor. The part cost $27 and the repairer charged $73 to fit it.
Apr 19, 2012 | Fisher and Paykel Dishwashers
Th-42pd25 humming sound and faint picture
Sounds like an inverter transformer humming, not producing enough current to display a bright picture. Check the caps in power supply, next to the plug where it says 24v and goes to the inverter board on the left side of tv. Or check for bad connections on inverter transformers on inverter board, Thanks
Nov 11, 2011 | Panasonic Televison & Video
I bought philips model no. 47pfl7403d/27 in 2008 .Suddenly last month it started skipping picture but we could hear sound.After few days it started smelling like something is burning and it stopped...
Seal deal w/ ours. I took it apart and the power supply board had the burn marks on it. Just ordered another power supply board (pn: 272217100571) for ~ $100. TV back panel comes off fairly easily to get at boards.
Jun 14, 2011 | Philips 47PFL7403D 47 in. LCD TV
No picture or sound. MODEL #19LA20Q
The faint light indicates that there is not enough power being provided to the other circuitry as well the humming sound is a good indication that the power supply needs ot be replaced or repair. If your TV is less then a year old, still under manufacturers warranty.
Let me know if you require further assistance.
Dec 03, 2008 | Proscan 19LA25Q 19 in. LCD Television
Prima l080i
Magic smoke GONE!
Seriously, the main power supply has failed, and requires service. You are probably well past the warranty period, but check with the TV's service center - that information should be in the documents that came with the TV.
Jul 07, 2008 | Prima CV2011 TV
Panasonic WIDESCREEN 52" hdtv: power tries to come on and then there is a burning smell. The power button LED on the TV flashes several times. This starting happening after the TV was on and suddenly...
check of fluid leak from the tubes, check to see where the burning smell is comming from. could be anode, hv wire, splitter, surge caps in h-circuit, but it sounds like a high voltage transformer.
what is your model number of your tv?
Apr 10, 2008 | Televison & Video
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Tv shuts off
the tv needs a tech to repair your tv it could be anything in the power supply that have burnt good luck.
Apr 07, 2007 | Toshiba 27A34 27" TV
Panasonic PT-51HX41 51" Rear Projection Television Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
