Rinse cycle only completes half of the time and cuts off
During the rinse cycle the washing machine will run and then cut off and does not continue the rest of the cycle nor the rest of the spin cycle. If I turn the machine off and continue to the next cycle manually and then turn back on, the machine will not run. The washing machine only completes all the wash cycle and half of the rinse cycle.
this is a kenmore ultra quality 80 series (15 years old)
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
At rinse cycle, cold water won't cut off after
if you unplug the washer does the water continue to enter? if the answer is yes you have a bad fill valve. is it only when you use cold water? what is the model number?
Apr 05, 2010 | Washing Machines
Top loader Speed Queen takes long time to complete one wash.
sounds like your belt is worn or the tension spring too tight on belt the vee part of the belt should not be rubber it should look like a material type coating to let it slip until it gets up to full speed (It,s Meant to slip) If it,s worn the rubber in the belt will grip too much.Hope this helps.Cheers.
Aug 06, 2009 | Washing Machines
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Bosch WFMC3200UC/01
Try cutting the amount of soap you use in half. If we use the detergent manufacturer's recommended amount (yes, we are using HE type detergents), suds remain and require additional rinse time or cycles, taking a long time. We cut the HE detergent in half and the times got pretty accurate and the clothes still came just as clean. Hope this helps you!
Apr 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
