Question about Saws
Need manual for mitre saw 137.285850
Angle cut
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Sears doesn't have a manual for that Craftsman saw. It must have been a small-volume seller or discontinued for problem issues. Find a neighbor who's experienced in using power miter saws; he should be able to show you anything you need to know. They're not complicated.
Posted on Jan 10, 2018
picatudo
  • 239 Answers
SOURCE: I have a makita mitre
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Posted on Dec 31, 2008
  • 18 Answers
SOURCE: Can you tell me what is causing my delta mitre saw
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
Posted on Jun 19, 2009
  • 10 Answers
SOURCE: Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Posted on Oct 26, 2009
  • 623 Answers
SOURCE: I cannot work out how to turn the mitre table when
Sometimes the knob has to be unscrewed to release it so it can be pushed down or move the table.
Posted on Apr 27, 2010
Devious1969
  • 76 Answers
SOURCE: Need Owners manual for Dewalt Mitre Saw Model 703
It's a multiple language manual. English is about 1/3 down.
http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw703_eur.pdf
Posted on Sep 06, 2010
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
How to mitre corners
using a set square , The angle if 45 degrees is machined into the handle draw a line at 45 degrees across the surface you wish to mitre cut
clamp a piece of timber along that line and use it as a guide to cut with the circular saw
Apr 27, 2016 | Saws
How to square up my saw and where I get a copy of the manual
With the saw unplugged manually pull the blade guard fully open and use a strong elastic band/string or otherwise wedge it open to give yourself full access to the blade.
Use an engineers square or at a push a good carpenters combination square measure the angel between the blade and the saw bed. you might find it's slightly off 90 degrees.
Ok, depending on the make of saw there will be a screw thread at the front or rear of the blade on on or close to the pivot points (where the bed tilts to allow different angles to be cut). it usually has a loking nut. Slacken off the locking nut and also slightly slacken off the tilt adjusting screws. You should be able to easily move the bed in relation to the blade. You will see the bed hitting the bottom of the adjusting screw.
Gently turn the screw and keep measureing the angle with the square. Make sure that the squares blade is tight to the saw blade and not touching the small tooth at the edge of the blade. there should be absolutely no gap either on the saw blade or saw bed when its correct.
Holding the screw with one tool getly tightedn up the locking nut ensuring that the main screw does not move.
CHeck everything again and tighten up the tilt mechanism.
Let me know with pictures if you need more exact info for your saw model and I can point out the parts.
Sep 13, 2014 | Saws
Mitre saw cod211lsm
Few budget tools and especially generic, brand engineered tools imported from the far east are superbly accurate but tend to be "near enough".
You didn't say whether it is a hand operated mitre saw or a power saw.
Most power mitre saws have a number of stops that can be adjusted or filed in order to calibrate the angles and this process should be done when the saw arrives. Once both 45 degree angles have been calibrated accurately the angles in between should fall into place fairly well.
One problem with low cost mitre (chop) saws, even some so-called professional saws is the construction is so light, when pulling down the handle the machine flexes and spoils the cut. This is especially true when the handle is not set exactly in line with the blade or when not paying full attention when making a cut.
Having experienced such saws I have learned much about them so when I visit a tool store I examine their stock by twisting, rocking and pulling the saw heads and the amount of movement in many new saws of popular brands is disgusting, even some pretending to be premium brands. So far only a few of the most expensive types have impressed me.
That doesn't mean the others are unusable and with care fairly accurate cuts can be made when a suitable technique has been developed - like using a rifle with bent sights...
Nov 27, 2017 | Tools & Hardware - Others
Looking for help scouts have a carpentry merit badge from the 50s they talk about using a BEVEl and a Miter tools can you help
The bevel is an angle fiding tool. it consists of a wooden section about 4" long with a swivel bolt at one end connected to a slotted metal blade (similar to a 1 foot steel ruler). The bolt has a wing nut and bolt to allow loosenig to allow the blade to rotate and slide to the required angle where it is locked into position using the wing nut.
The mitre is a wooden block with slots cut into it at pre determined angles. ie 45 degrees. When cutting a mitre joint the wood is placed against the block and the saw follows the line of the slot cutting the 45 degree angle.
Hope this makes sense and good luck
Feb 18, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Why when i cut a bit of 6" skirting board it does'nt cut square on a brand new ryobi ems 2026 sliding mitre saw
Don't ever assume that the markings on the angle setting are correct and accurate. Always check squareness with a square before you use a miter saw. With almost all brands of power tools being built overseas nowadays there is unfortunately a question of accuracy on most brands. Always check.
Mar 16, 2009 | Dewalt Mitre Saw Workstation
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
145 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
