Question about Frigidaire Electric Dryer
Thermal imiter tppe
Will not start
  • Official Brand Answer
  • 4,342 Answers
Hello - Try resetting the unit at the household circuit breaker first and then retry the unit. If this proves to not be successful, then typically this is something that a professional would need to diagnose. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Posted on Nov 05, 2012
Just replaced high imit thermal fuse. The dryer belt squeks after 30 minutes on high manual mode. It seems the dryer is running much hotter than usual maybe causing the belt to squek. Any idea???
You may possibly have a bad temp control stuck on that caused the hi limit to open in the first place. That may be why you have a hotter than normal dryer. Temp controls are usually near the hi limit. A round disk with either 2 or sometime 4 wires hooked to it. Also check for a possible block vent keeping the hot air from venting outside.
Mar 20, 2015 | Dryers
Car not starting in morning
It sounds as though you are imitating a cold start injector by pouring fuel into intake. I would start there
Aug 03, 2014 | 2003 Pontiac Grand Am
EeePC 900 won't start, no noise from fan, only the lights for harddisk, wifi and "the lightbulb" are on, indicating that there is power. Why???
sensor to the cooling fan defective.therefore imitating shutdown to protect main board from overheating.
your notebook needs service . Possible dust accumulation around the cooling core and fan.
Jun 23, 2011 | ASUS Eee PC 900 Notebook
The shutter release button on my Nikon MB-D10 doesn't appear to be working. The switch on the side is turned to the dot as it should be. Everything in camera is set to use the grip properly and all the...
You’ve done the obvious thing by insuring that the release switch is turned on. Try toggling it a few times. The big question is about grey market and imitations. That’s a serious issue with battery packs. The imitation models fail all all the time.
Dec 10, 2017 | Cameras
How to fix the software counterfeiting?
Try to start by urself first, don't buy and patronize any imitated products!
Dec 01, 2010 | Microsoft Windows XP Professional
My china phone is block
hey dude, ur using a china phone? anyway, there are 2 kinds of china phone, there's the authentic one and there's the imitation. the imitation really sucks coz its not guaranteed to last a long time. they are poor in quality and they easily breaks. why not get yourself a better one by purchasing the authentic coz they may be expensive but its worth all your effort. thanx!!!
Aug 18, 2010 | Cell Phones
Optra T610
If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
May 01, 2010 | Lexmark Optra T610 Laser Printer
My new Samsung mobile's battery doesn't work for an expected time.whenever I reacharge the battery getting charged for a while and after the full charge message again if I charge it exactly for 10 minutes...
your battery is defective replace it.. maybe its sub standard..many batteries from china imitate it. it looks like original but won't work as a original...man imitated batteris are everywhere at cheapr price..beware
Nov 26, 2009 | Cell Phones
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
IMITATION LEATHER
Depending on the overall thickness of the proposed job, this should be fine provided you bear a few things in mind, and monitor progress.
Use a new size 14 or leather needle, and be prepared to renew needle several times depending on the size of the job........start the sewing by turning the handwheel to create the first stitch and run at low to moderate speed
.....if the machine feels like it is struggling from the outset, do not continue.....
if it runs fine and only starts to labour after a while, the needle will have become blunt...replace it.
For each new seam, start by turning the handwheel manually, just to get things started.....you may also find this helpful at the end of seams for the lock stitch
Also...
The presser foot tension may need to be relaxed a little depending on the overall thickness of the job
Feb 09, 2008 | Singer 7466 Mechanical Sewing Machine
Frigidaire  Electric Dryer Logo
47 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
