Question about Oldsmobile Vehicle Parts & Accessories
Diargram front engine mount
  • Oldsmobile Master
  • 14,417 Answers
Need your vehicles info.,year,make,model and engine size to help you.
Posted on Nov 05, 2012
Torgue specs on the front engine mount bolt for a 2004 harley elctra glide classic
2004 Touring Engine Mount Torque Value
Front engine mount to frame bolts 15-20 ft-lbs 20-27 Nm
Front engine mounting bracket to rubber mount bolt 15-20 ft-lbs 20-27 Nm
Apr 20, 2014 | Harley Davidson FLHTCUI Electra Glide...
Replace engine mounts are they the same mounts on 2010 front an rear
Hi Anonymous, there is only two motor mounts on rubber mounted engines, one in the bottom front of engine and one at the top. 99% of time is it's the front motor mount that goes bad. The front motor mount is not the same as the top. The rear shocks act as a rear motor mount. Please visit website below:
Harley Touring FXR The Glide Pro Front Motor Mount user objective review
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 24, 2014 | Harley Davidson Motorcycles
Looking for cam belt diargram
According with the size engine, try looking HERE.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 20, 2012 | 1999 Volkswagen Golf
Loooking for cam belt diargram
Need the diargram to put back on the belt it is a 2010 ford fusion 4 cylinder
You may try looking in various places under hood, front of engine, at inside fender panels and under hood panel itself for a diagram of belt routing.
Aug 27, 2011 | Ford Fusion Cars & Trucks
Trying to remove an alternator from an 06 altima
Removal and Installation L4-2.5L (QR25DE) Engines To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Engine cover
    • Front/right-side engine undercover
    • Drive belt
    • Alternator harness connector
    • Engine ground wire from top mount
    • Alternator upper and lower mounting bolts
  3. Set the alternator aside and remove the top mount.
  4. Remove the alternator.
To Install:
  1. Slide alternator in place.
  2. Install or connect the following:
    • Alternator top mount
    • Drive belt
    • Engine cover
V6-3.5L (VQ35) To Remove:
  2. Disconnect the negative battery cable.
  3. Drain coolant from the radiator into a suitable container.
  4. Remove or disconnect the following:
    • Radiator
    • Front/right-side engine under cover
    • Drive belt
    • Idler pulley
    • Alternator adjustable top mount
    • Alternator lower mount bolt and nuts
    • Alternator lower front bracket bolt
    • Alternator harness connectors
    • Alternator
To Install:
  1. Install or connect the following:
    • Alternator in place
    • Idler pulley
    • Drive belt
    • Radiator
  2. Replace the engine coolant.
  3. Connect the negative battery cable.
  4. Start the engine and check for leaks.
  5. Recheck coolant level and top off as needed.
Oct 15, 2010 | 2006 Nissan Altima
I need a serpentine belt diargram for a 1987 ford f-150
There are 5 different engines available for the '87 F-150.
Go to this site and choose the Ford F150 and appropriate engine.
When the results come up, scroll down and you will see an icon for a camera next to serpentine which will show you the diagram...
http://www.gates.com/part_locator/index.cfm?location_id=3598
Dec 27, 2009 | 1987 Ford F 150
Removal and installation of an auto trans in 2002 toyota camry
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the transaxle fluid.
  3. Remove or disconnect the following:
    Negative battery cable. On vehicles equipped with an air bag, wait at least 90 seconds before proceeding Battery Air cleaner assembly Throttle cable from the throttle body Cruise control actuator cover and connector, if equipped Ground wire Starter Speed sensor connectors, direct clutch speed sensor, and the park/neutral position switch connector on the transaxle Solenoid connector on the transaxle Shift control cable Oil cooler hoses Front side transaxle mounting bolts Front engine mounting bolts Oil cooler line mounting bolts from the front frame Upper transaxle to engine mounting bolts
    0900c15280197a59.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Tie the steering rack to the engine support fixture components, as shown-Avalon and Camry
    Front exhaust pipe Engine side covers and undercovers Both halfshafts Front side engine mounting nut Rear side engine mounting bolts (remove hole plugs) Left side transaxle mounting bolts Steering gear housing Front frame assembly Rear end plate mounting bolts Torque converter cover Torque converter retaining bolts Remaining transaxle mounting bolts Transaxle
Apr 09, 2009 | 2002 Toyota Camry
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Oldsmobile Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Robert Swatek
Robert Swatek
Are you an Oldsmobile Vehicle Part and Accessory Expert? Answer questions, earn points and help others
