How do I use this and how do I fix it to my dash in my car
  • 691 Answers
This link has instruction for the 590i but i would think the detail is same:
http://support.radioshack.com/support_auto/doc34/34390.htm
Posted on Jan 04, 2013
How to fix the Dash lights?
It's probably just your fuse. The fuse for your dash lights also controls your taillights. Bill.
Jul 03, 2014 | 2000 Toyota RAV4
How do you fix the dash and running lights?
With what info you've given,it would not have been the light switch or the rheostat for changing dash light brighting.Since both the dash lights and running lights are not working,first thing I'd have done is replace the fuse,since both are o the same fuse.Kinda like when my Toyota wipers would stop,the overdrive stopped working too.Both were on the same fuse.Replace the fuse and good to go.I carry fuses with me.
May 12, 2014 | 2000 Nissan Frontier
Digital dash in my 1995 lincoln town car went off when alternater was replaced
I would first check the fuse for the dash, since that should be simple and a cheap fix. If not, the light in the dash may need replacement. The final and most difficult possibility would be a fault in the wiring between the dash lights and the power source.
Nov 09, 2012 | 2007 Lincoln Town Car Signature Limited...
My 1995 dodge 1500 dash lights wont come on
your lights needs fixing go to your nerest car fixing shop and they will do it for you
Feb 05, 2012 | 2000 Dodge Ram 1500 Truck
My dash is curling up starting at windshield .
The dash in 1999-2005 Pontiac Grand AM's is known to have issues with "curling" and discoloration. While the only solution to completely fix the issue is to replace the dash, there is another, less professional way to fix it. Start by using a blow dryer to heat up the top of the dash, hold the hairdryer several inches from the dash and move it back and forth until the dash is soft enough to be manipulated. Now, pull the dash up and away from the windshield, and using a strong glue such as "Gorilla glue", glue the underside of the dash. Now push the dash back into place and lodge a hard object between the dash and the windshield. Let the glue dry for at least 16 hours before removing the object used to hold it in place. The dash should no longer looked "curled".
Mar 13, 2011 | 1999 Pontiac Grand Am GT
Bulb in four wheel drive dash switch burned out
if it burned out, but the 4wd works, the only way to fix it is to remove the dash. you might have to replace the switch, or just the bulb. a cheap fix, but one that is not fun to fix.
Dec 10, 2010 | 1998 Ford Expedition
My 1988 Porche Carrea has a slight crack in the dash above the steering wheel. Is there a way to mend/fix without replacing the whole dash?
Hello aft2
unfortunately there is no fix for your problem,i have the same on my car.
The dash is way to expensive, so I learn to live with it.
The are companies who could fill the crack but it does not come out good
proporsche
Oct 04, 2010 | 1988 Porsche 911
1987 pontiac firebird, does anyone know how to fix dash lights.?
you have to take out the gauges, they will be on the back. In some cases you have to take apart most of the dash to get the instrument panel out, sometimes you can just take the trim off the instrument panel. I had to take apart most of my dash in my 86.
Oct 04, 2009 | 1987 Pontiac Firebird
Have 1996 lin towncar where n how 2 fix blend door 4 heat n a/c
In order for the blend door actuator to be replaced, the dash must be removed from the vehicle.
Feb 07, 2009 | 1996 Lincoln Town Car
Dash removal 1996 lincoln tc
Most likely they ( the Ford dealer) cracked the heater core when they pulled the dash to fix the other problem, I worked as a Ford dealer tech for 20 years and this is entirely possible.
For poster markjschwab, the noise is the blend door motor, so your dash will need to be removed to fix that issue, be careful of the heater core or just replace it while the dash is out, they are cheap.
Oct 24, 2008 | 1998 Lincoln Town Car
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
