My Kenmore stackable washer does not adjust to any other wash capacity buy small
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number?
Posted on Nov 05, 2012
jsrock516
  • 5911 Answers
SOURCE: water keeps draining
You may be experiencing what is known as "siphoning".  If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain.  You need an air gap in order to prevent this.  Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches.  If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests.  Makes sure there is still an air gap around the hose.  That is, make sure the hose isn't seated so tight that it seals off the standpipe completely.  This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening.  Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe.  In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor.  If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here.  There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem.  You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise.  This is air being reintroduced through the drain line.  I hope you find this information helpful.
Posted on Oct 27, 2007
AlmostBob
  • 550 Answers
SOURCE: Kenmore 90 series top loader washer water level.
There are easy checks before you replace the level selector body
remove the trim plates at both ends of the control panel to expose Phillips head screws 1 at each end. remove the screws
lift and swing the control panel up and over the back, it is hinged at the top.
The washer can be operated in this condition for testing
1 Rremove the air hose, and blow it out.
often water remains in the tube after changing levels, the water is not compressible so a small change in water level in the tank, makes too much difference in the sensor.
reconnect the tube and try a cycle ~1/3 chance of fixing it
If fail,
2 The spring inside Kenmore water level sensors that reacts to air pressure in the tube is not up to the job and stretches, not noticeable till changing water level settings moves the anchor point of the spring.
pull off water level knob from control panel front, from control panel back depress lock tab at right of level selector body rotate counter clockwise 45 deg and remove
adjacent to selector knob shaft is 1/8inch nut, turn clockwise to raise water level counter-clockwise to lower water level, test, adjust, test adjust ~1/2chance of fixing it
If fail
replace level selector body
Posted on May 26, 2008
mikedurland
  • 481 Answers
SOURCE: What is the capacity in cuft of a Kenmore 70 Series washer?
it is a large capacity 2.3 cf with a small case.
Posted on Jun 27, 2008
  • 403 Answers
SOURCE: kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Posted on Oct 05, 2009
housejess
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    What is the capacity of the Kenmore 70 series model#11022722101
    In the Kenmore line of washers and dyers, the 70 Series is a mid-priced family appliance that handles an average family's laundry needs. All appliances in the 70 series are freestanding and do not have stackable units. Available with both English and Spanish instructions, this mid-line series of appliances is suitable for almost any household needs. Kenmore Series 70 Specifications eHow
    Jun 08, 2015 | Kenmore Washing Machines
    What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
    ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
    Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
    Stackable kenmore washer dryer
    could be a clogged pump or drain hose causing the water to spin over the top
    Jan 15, 2013 | Washing Machines
    Kenmore stackable washer wont work on Cold cycle only hot water
    Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
    Washing Machine2_bing.gif Problems No Water
    http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
    Washing Machine Fix Washing Machine No Water
    http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
    heatman101
    May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
    Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
    My kenmore stackable model number has been
    there should be a number on the belt take it to the spares place and they should be able to match one up for you
    Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Owners Manual for Sears Kenmore Stackable Washer/Dryer
    how do you seperate the stackables for moving
    Oct 13, 2008 | Washing Machines
    Kenmore Model 94812301 Stackable Washer/Dryer
    try adjusting the feet on the bottom. apart from that the bearings may need replacing.
    Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
    Washing Machines Logo
    18 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
