Question about In Store Used Used Peavey 358-S 131 05/09/2012
Need a crossover for peavey 358s - In Store Used Used Peavey 358-S 131 05/09/2012
Peavey instructions
I would put the crossover just before the amp(s). The kosmos v2 just after the signal source. Always turn the levels down before powering it up.
Aug 10, 2014 | Peavey Kosmos V2 Generator-processor...
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
Horns wont play in peavey 215
broken crossover or bad diaphram or wire off in the high circuit.
Mar 13, 2014 | Peavey PV-215 Dual 15 2-Way Speaker...
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Need to replace the crossover in a Peavey SP4G Speaker, What is the Part # and where to buy it?
Need to replace the crossovers in a pair of Peavey SP4G Speakers, where can I find the part
Dec 28, 2009 | Peavey TLS115X Speaker
Blown crossover
Sounds like the crossover is smoked. Unusual, but it happens. Just call a Peavey service center for the part number and you should be able to order direct from Peavey. If you have problems getting the number, let me know and I'll try and get it for you.
Dan
Aug 18, 2008 | Audio Players & Recorders
Blown crossover in a Peavey Pro-Sub 15" speaker cab. Can this be repaired? If not, where can I get a new crossover? I went to Peavey's web site and this particular crossover isn't on there.
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
In Store Used Used Peavey 358-S 131 05/09/2012 Logo
162 people viewed this question
Top In Store Used Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an In Store Used Audio Player and Recorder Expert? Answer questions, earn points and help others
