Question about Black & Decker Saws
Jigsaw motor runs but blade doesn't move
  • laquitaherri
    laquitaherri Nov 08, 2012
    my husband took it apart, made a pin out of a nail he cut the head off of and it is now working again
  • 7 Answers
SOURCE: I bought a used black & decker jigsaw no. 7548
several methods 1) turn collar near top of blade. spring return. same in reverse to insert. 2)Older type may have spindle screw which draws up collets to clamp blade. access to screw may be through body directly over blade shaft. thats all for now.
cheers
Posted on Aug 27, 2009
  • 5 Answers
SOURCE: after using my jigsaw for the second time, the
try using a little spraying a little oil on it also allot of the time there is a small screw to loosen the lever.
Posted on Feb 28, 2011
SOURCE: Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Posted on Apr 24, 2011
canwoodjc
  • 3301 Answers
SOURCE: just got a B&D single
place your model number on this link http://www.blackanddecker.com/Manuals.aspx
Posted on Jun 30, 2011
bronk50
  • 27725 Answers
SOURCE: INSTRUCTION MANUAL for a 350watt Bosch jigsaw PST 50-2
http://powertool.manualsonline.com/manuals/mfg/bosch_power_tools/bosch_power_tools_saw_product_list.html
hope it helps
Posted on Nov 19, 2011
The blade broke off inside and I can't get it out. Please help me figure how to get it out.
moden jigsaw blades are held in with a taper chuck system
disconnect the unit from the wall socket
push the spindle all the way in
now press on either side of the blade holder and that should move down releasing the blade
now while holding that section down turn the unit right side up and the broken bit should just fall out
Oct 13, 2015 | Skil 4495-01 6 Amp Orbital Jigsaw
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Nov 06, 2014 | Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
Blade doesn't move (reciprocate)
The drive shaft for the blade is stripped or broken. take it back where you bought it.
Oct 31, 2012 | Dewalt DW303 Heavy Duty 65 Amp...
Motor runs but blade does not move
It sounds like you have a problem somewhere between the motor armature and the reciprocating mechanism that makes the blade move up and down. Unfortunately the only parts Skill has available for your saw are the switch, cord, brushes and blade holder You'll could take it apart to see if something came apart that is repairable without parts. If you need parts like gears or motor parts, they are not available.
Jul 08, 2012 | Skil 4390-01 Variable Speed Orbital Jigsaw...
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
Need instruction manual. how do you install the blade into the Acdelco AC-PT009 jigsaw?
Use the supplied hex to loosen(not completely) two bolts accessible through the vertical slots in the plastic front plate. Push the new blade into the loosened holding plate with the smooth back edge of the blade against the back wheel. Tighten and check blade firmness before using! Wear protection, use the correct blade, run at max speed before contact, and use a supported cutting bench. Think, plan, execute, and be safe. The motor is only half the power of regular models, so take short rests, and use only for minor jobs.
Aug 15, 2010 | ACDelco AC-PT009 3.8 Amp Variable Speed...
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Saws Logo
639 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
