Question about Frigidaire Kitchen Ranges
Replacing frigidaire compact 30 electric burner element
Model Enhanced-533ch Serial #51c72 49
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
jyackle5
  • 8197 Answers
SOURCE: instructions for frigidaire oven
an f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Posted on Dec 16, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
SOURCE: Compact 30 Frigidaire Model rbe539n range/oven.
Be sure the timer (right most knob) is set back to MAN (manual) after cleaning in order for the oven to work.
Posted on Apr 09, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Frigidaire model number Fef386cc and serial vf41228055 burners work and clock and light in the oven but the burners do not heat up how do u fix that
CAUTION 220-240 VAC may be encountered!
FIRST check your power at the plug.
With a properly insulated voltage meter, IT MUST read 230AC between the two flat holes. 120VAC between the third, usually round hole.
If that is verified proceed to the power cord and trace the poere internallyl
I am providing manuals and schematics according to your Model Fef386cc.
Frigidaire 30 Freestanding Electric Range
Oct 02, 2015 | Frigidaire Kitchen Ranges
Www frigidaire com
If you can giggle the element and It comes on you need a new element socket. Very easy fix.
Jun 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Burner element broken
Hi friarjp - I am happy to assist you. First, I will need your model number to better address the issue at hand. With this information I can verify which part you need exactly. Is it the right, left, back or front burner element or are you referring to the bake and/or broiler element.
Jan 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
AFTER REPLACE The COOKiNG ELEMENT , No HEAT on The ELEMENT
Check the plug that the burner connects to, often the two have to be replaced as a pair. I presume that you already checked fuses and the continuity of the burner.
Apr 11, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element not warming up everything else on stove and oven working
Probably a bad burner switch.Take the model # to your local shop and tell them which burner it is.Hope this helps.Have a great Thanksgiving.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need to know if the burners come out of my stove
Hi, The burners should pull up and out. They plug into a receptical and should release fairly easy.
While you have the burners out, check the ends and see if there is any sign that they have been burning/arking. Thet should be clean before putting them back in. I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Nov 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
