Question about Dryers
My dryer kenmore elite 11074972300 doesn't heat
    Problem Solver:
  • 11 Answers
I had this problem with one of my dryers and it turned out that the heating element was broken. It is a repair man that you need now I'm afraid.
Posted on Nov 04, 2012
SOURCE: my kenmore dryer is not heating
check the thermal fuse
Posted on Dec 27, 2007
SOURCE: Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Posted on Jun 09, 2009
  • 135 Answers
SOURCE: Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Posted on Aug 27, 2009
Testimonial: "I replaced both works great thanks for the conformation."
SOURCE: kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Posted on Oct 08, 2009
  • 552 Answers
SOURCE: sears kenmore elite oasis dryer 110 67032600
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Posted on Mar 11, 2011
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
The dryer doesn't blow any heat 11074972300
Check heating element with Ohm meter should read something.
Infinite reading means the coil has burnt out. replace.
Nov 04, 2012 | Kenmore 95087 Gas Dryer
Kenmore H4 not starting
Check the door latch. If the door doesn't latch, the dryer won't start
Oct 03, 2012 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite dryer model # 11070952990 that will not heat up, I replace the glow bar ignitor, I don't know what i'm missing.
Check the thermal fuse. You can temporarily bypass it by hooking its two wires together then see if it heats.
Sep 24, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
My daughters "Kenmore Elite Gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 01, 2011 | Dryers
I have a kenmore elite model #110.95088400 that doesn't heat when drying. I checked the thermal fuse and it goes to continuity. I checked the hi limit thermostat and it was continuity, the thermistor...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
My kenmore elite he 3 dryer is not working. well, the buttons go on and the dryer starts to spin when everything is set but when I open the dryer, everything is soaked still. there is no heat at all. on...
more then likely it is the thermal fuse, or the heating element here is a link:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 06, 2011 | Dryers
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
Dryers Logo
90 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
