Question about Numark TT1610 Turntable
I am running my turntable trough a large amp and very little sound is coming out from the vynal
I have me docking station on full wack and not much volume is coming from the turntable atall
What power plug do i use with unitek data hdd docking station
The Y-2041 comes with a 12V 4A power supply which is not quite as large as the typical laptop supply. It is manufactured by Ktec and the model is KSAH1200400T1M2.
Jan 19, 2014 | BestOfferBuy Unitek Y-2041 USB 2.0/eSATA...
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
Trying tocopy album direct to i pod sound quality very low ?
Hi, you need to use a pre amp between the turntable and ipod to up the output. Alternatively you can run it through a mixer or amp with dedicated phono input. styluscity@gmail,com
Sep 10, 2010 | ION Audio iPROFILE LP to iPod DJ...
Sound does not come out of docking station
It is most likely the 30 pin connector on the Logitech that is the problem. They can break if the incorrect iPod inserts have been used. Try playing someone else's iPod on it, if no go it's busted. Repairs are difficult if not impossible. Sorry
Nov 25, 2009 | Audio Players & Recorders
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
Aug 22, 2009 | Toshiba Dynadock Port Replicator, Docking...
Recording tracks from vynal stop recording after 1minute
2 solutions, check all hook ups and make sure they ok, 1. see if your turntable can be played thru the stereo like amp or receiver with your audio cords and record that way to cassette tape. 2. if your turntable can go thru computer using usb cord and make sure you have download your software that came with your turntable if it didn't go store and like office max or simlair buy a product called inport deluxe by xitel
Jul 26, 2009 | Numark ttUSB Turntable
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
My docking station has a loose conection where the i pod sits!
You need to dismantle the unit and resolder the ipod socket. It is soldered to the board and the solder joints crack under the strain. This will happen to every JBL dock eventually.
Jun 19, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
Hp photosmart 945 lens is stuck
Looks like the large lens cannot get it's lense out with the electric drive. This is operated by a little motor with gears. The clicking sound is from gear-teeth. Your guide shaft (3 of them) may be blocked by sand or dust or broken guide-pins.
Once the large lens is fully out. The small internal lens will be moved in and out for zoom. I have recently fully dissassembled my broken HP945 which was fallen on its lens in extracted mode (under charge from docking station). If you want pictures how it looks inside, let me know. rene_bdm@solcon.nl
Jun 04, 2008 | HP Photosmart 945 Digital Camera
Numark TT1610 Turntable Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
