Question about Genie Company Genie Series III 3 Button Remote Control
How to connect multiple remotes to my genie intellicode?
2 Suggested Answers
SOURCE: FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Posted on Jul 14, 2011
What size battery is used in the genie gitc390 remote
i buy a new battery for my genie gitc390 garage opener but still doesn't work, the red light is on when i press the button. what's the problem?
Nov 14, 2012 | Genie Company IntelliCode GICT390-1BL...
How can I connect 3-button remote to my genie intellicode model IS550/A?
The button closest to the Genie logo is the one that works, I just programmed it by pressing & holding the black button underneath the light cover until the red light above the button goes solid then blinks then stops blinking. Next I pressed the same button once and the red light blinks then pressed the button on the remote once then once more and it was all set.
Apr 19, 2012 | Genie Company Genie Series III 3 Button...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Someone guessed our code and numbers were outlined with a marker.... we need to change code but lost our manual.
Hi
There is a bunch of manuals for Genie intellicode systems on genie's website just click here to go there.
Hope this helps
Mar 07, 2011 | Genie Company IntelliCode GICT390-1BL...
My opener opens both garage door I only want it to open one
You will need to erase both openers out and recode.
Press the learn button on the motor head until the led light goes out on it. Wait for 2 minutes. ----- Press and release the learn button and then press the button on the remote 3 times and try. Genie openers sometimes take multiple times doing this to code in for some reason. For multiple remotes repeat from -----. For the other opener do the same thing but with a different button on the remote, unless you have a 1 button remote then use different remotes for the 2 doors. Thanks BB
Aug 31, 2010 | Genie Company IntelliCode GICT390-1BL...
I have a genie H6000A garage opener but the remote is missing. So I'm planning on buying a new remote control but I also need to know how to reset it.
There is a button on the motor head you can press. It will be black more than likely. Press and hold this button until; the led light goes out by it. ----- The press and release the learn button and then press the remote button 3 times , wait for 5 seconds and try. Sometimes Genie remotes take multiple times to program. For multiple remotes repeat from -----Thanks BB
Mar 28, 2010 | Genie Company IntelliCode GICT390-1BL...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Change battery in GICT390 3 button remote
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Genie Company Genie Series III 3 Button Remote Control Logo
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
