Question about Visioneer OneTouch 8800 Flatbed Scanner
Installation software I purchased my scanner in 2002. Through several moves, several room mates and twice as many free loading house guest the installation and PaperPort software can no longer be found. I just upgraded my system and need to reinstal the software but without the CD i am lost. Can this be done over the internet or do I need to acquire another CD? If so, please tell me where. Thank you, Tani
    Genius:
  • 2,985 Answers
Go to the Tech Support they may have a driver down load facility- but the software like paper port may be a problem but there are plent of free software out there like picasa that do it pretty well all.
Posted on May 22, 2007
How do you restrict calls outgoing from a guest room?
Hello, Sheila -
Clarification: By "guest room", do you mean an extra bedroom in your home where visitors stay, versus a guest room at a hotel or guest house? Also, do you mean a call from a land line telephone? (Your question landed in the Fixya.com category for cell phones.) If so . . .
You can disconnect the modular telephone connection from the telephone wall outlet and move the land line telephone and connecting cord from the room. No telephone connected to the telephone outlet . . . no telephone calls.
Best wishes.
Mar 08, 2018 | Cell Phones
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Jan 07, 2013 | Canon imageCLASS D480 Black and White...
I haven't used my Optic Fil 7200i (plustek) since upgrading to Windows7. Also, I have moved and my software disk didn't make it in the move! Is there a way to get one mailed to me: Bailey...
You can purchase the software disk from this link:
http://plustek.com/usa/buy-parts-and-accessories.html
Alternately, you can download the installation software/driver free of cost from the manufacturer's download website by clicking this link
On the page which opens, enter OpticFilm 7200i in the Serach box under "Option 1: Search By Product Name" and click the Search button (See attached image)
Then select OpticFilm 7200i from the results window. Download the driver in .zip format from the list which opens. After the download completes, extract the .zip file to open the driver file.
Here is the direct link to the driver file.
Hope this solves your problem. Thanks for using FixYa.
Jan 21, 2011 | Plustek OpticFilm 7200i Film Scanner
Installing Canon N650U scanner on a MacBook Pro
free driver @ http://www.soft32.com/Download/Free/CanoScan_N650UN656U/4-170676-1.html
Jun 13, 2010 | Canon CanoScan N650U Flatbed Scanner
Scanner no longer communicates with the pc
Have your scanner turned on when you boot up your computer. Go to Programs, Acessories, Scanner and camera wizard, and it will give you directions if the scanner is not installed and recognized.
Aug 21, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
1990 buick century thermostae removal trouble
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
CAUTIONWhendraining the coolant, keep in mind that cats and dogs are attracted byethylene glycol antifreeze, and are quite likely to drink any that isleft in an uncovered container or in puddles on the ground. This willprove fatal in sufficient quantity. Always drain the coolant into asealable container. Coolant should be reused unless it is contaminatedor several years old.
  1. Some models require you to remove the air cleaner assembly from the throttle body.
  2. Somemodels with cruise control have a vacuum modulator attached to thethermostat housing with a bracket. It your vehicle is equipped as such,remove the bracket from the housing.
  3. On the 4-cylinder engines,unbolt the water outlet from the thermostat housing, remove the outletfrom the housing and lift the thermostat out of the housing. On allother models, unbolt the water outlet from the intake manifold, removethe outlet and lift the thermostat out of the manifold.
0900c152800cc162.jpgFig. 1: Loosen the clamp securing the hose to the thermostat housing 0900c152800cc163.jpgFig. 2: Remove the bolts securing the housing, then pull it away 0900c152800cc164.jpgFig. 3: Make a note as to which end of the thermostat fits in the housingTo install:
  1. Clean both of the mating surfaces and run a 1/8 in. (3mm) bead of R.T.V. (Room Temperature Vulcanizing) sealer in the groove of the water outlet.
0900c152800cc165.jpgFig. 4: Make sure both of the mating surfaces are free of any old gasket material
  1. Installthe thermostat (spring towards engine) and bolt the water outlet intoplace while the R.T.V. sealer is still wet. Tighten the bolts 17-21 ft.lbs. (23-28 Nm) on all but the 2.2L engine. Other engines tighten to 89inch lbs. (10 Nm).
  2. The remainder of the installation is thereverse of removal. Fill the cooling system, start the engine and topoff. Check for leaks after the car is started and correct as required.69566fc.jpg0a9a786.jpgdf83f61.jpg59df070.jpg
Oct 19, 2008 | 1990 Buick Century
I purchased the Norton 360 Version 2.0 yesterday, and am trying to load it onto my machine. After checking for an updated version, I get an error message saying that the updated version will not load onto...
If you are having problems installing security software, and have 1500 documented problems, you may have a severe MALWARE infection. MALWARE (Virus, Spyware, adware etc.) often attack, disable or prevent the installation of security software.
Depending on the severity and how deeply imbedded the walware infection is determines the final resolve. UNfortunately, the final answer often is a complete reformat and reinstall of the operating system.
Things you can try:
If you can, download and run SPYBOT Search and Destroy from www.download.com
Other applications you may try to attack the problem are:
AVG antivirus from free.avg.com
ccleaner and Smitfraud fix from http://www.gur.in/download/
Often, it is just too much work to get rid of a massive infection and mort effective to format and start with a clean drive and install the security software before re-connecting to the internet.
Sep 03, 2008 | Computers & Internet
Canoscan n650u
Here download it from this link, just select your operating systems driver
CANOSCAN
scangeartoolbox for windows
cs_toolbox classic for mac
pls dont forget to rate solution as fixya, thanks!!
May 03, 2008 | Office Equipment & Supplies
Visioneer OneTouch 8800 Flatbed Scanner Logo
71 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Alun Cox
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
