Question about Garden
Chainsaw will run for 5 min then stalls out
Craftsman 18 in 36cc chainsaw, will run like a Raped Ape for 10 min then stalls out when squeezing trigger, replaced Spark plug and cleaned filter, full of gas, but at a loss as to why?
  • 1 more comment
  • jaynpat Jan 06, 2009
    Cleaned the Fuel Filter which helped, seems no one carries replacement filters, even Sears, so I ordered on-line, which will take afew days, but think this will solve my problem, if it does, I'll change mt rating to FIXYA - Thanks for your Help
  • jaynpat Jan 13, 2009
    Still have the same problem, changed fuel and air filters, fresh gas, carb bolts are tight, cleaned the saw, just don't know what else to try.
  • bczerkie May 11, 2010
    when it stalls will it Immediatly restart?
    what is throttle response like?
    if will not restart or repeats same loosen gas cap to reduce vacuum lock then retighten, retry,
    if this helps check for pinched vent line or other tank venting issues.
    Don't run or start with cap loose.
    President:
  • 2,692 Answers
Fuel is induced into the engine via the diaphram to the carburator. If the diaphram is weak or has a hole in it, it will run out of gas just like you discribed..
Posted on Jan 18, 2009
  • 36 Answers
I would change the in tank fuel filter. Do this by draining the fuel and fishing it out with a stif piece of wire it is conected to a rubber fuel line in the tank. Also check to make shur the screws that hold the carburator to the engine are tight.
Posted on Jan 04, 2009
  • floyd giles Jan 13, 2009
    Adjust high Idle Screw try turning out 1/8 to 1/4 turn
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Craftsman chainsaw runs then stalls when starting to cut
allways use full throttel when you insert the chainsaw
Jul 04, 2014 | Husqvarna Garden
Chainsaw trips circuit breaker
Does the circuit breaker trip before squeezing the switch? Check the power cord - there's a short
Does the chain move freely before squeezing the switch? If not, and the circuit breaker trips while squeezing the switch, your chain is too tight.
Bottom line - tell us when the breaker trips and what you were doing when it tripped.
Dec 07, 2012 | Craftsman 16" Electric Chainsaw Chain Saw...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Weed wacker starts and runs but only on idle or part throttle. Full throttle stalls. New gas and plug does not help at all. when tank gets empty it runs like a raped ape for about 20 seconds before the...
My guess is you are getting way too much fuel. (Runs with choke "on" too? Maybe a little smoke with the correct oil ratio?) If that is true then there are 2 possible solutions. First has anyone tampered with any of the set screws on the carb? If no DON'T touch em. It runs good at the end (20 seconds of raped ape) because at that point the fuel air mix balances out for a short period. But its in a aberrant mode, normally it would putter down and out. Flooding or "too much fuel" happens from 2 causes usually. one is you got a tiny spec of dirt, or gas varnish, or recrystallized whatever holding the needle valve open, letting too much fuel in. Try pulling off the fuel lines from the carb and spraying in some Gumout or carb cleaner, let it sit 5 min. Spray again, then blow out the passages in both directions with a compressed air source or a clean separate vinyl hose piece you can blow thru. Make sure the air filter isn't full of silt and dust. (Not enough air can cause this too, but its a bit different...not by much though) After you clear out the carb reconnect the lines and try it again. Let me know what happens. If the set screws were tampered with, I then have another set of steps to follow.
May 10, 2010 | Craftsman 25cc Gas Line Trimmer
My craftsman 205mph leaf blower starts and runs for 4 min stalls
Replace the fuel filter that is inside the fuel tank. Purchase a can of Seafoam Motor Treatment. Ask for it at most auto parts stores and WalMart. Pour in the correct amount as listed in the instructions, and fill the tank with fuel. Start the blower and run it wide open. If your problem is a fuel system problem this may very well solve the problem. This is one of the best fuel system cleaners you can buy.
Nov 07, 2009 | Garden
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Garden Logo
539 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
