Question about Cameras
Does plugging my camera into the computer does that charge the battery
    Problem Solver:
  • 11 Answers
If it does, it will show you that on the screen. Look at all the options offered when you plug it in to download your pictures.
Posted on Nov 04, 2012
Not Charging
Page 18 of the manual says: Only use cable and AC power adapter, delivered with your camera to charge the battery. If you use another adapter, or cable the camera battery could not charge or not work properly.
The manual, does not indicate you should be able, or you could charge the battery, when you connect it to a computer. And although on the outside a cable can look the same, it would be better you use the original cable, that came with the camera. Make sure you switch off the camera before charging and check if all contacts in the camera and on the cable are clean and not bent.
Mar 22, 2014 | Samsung ST66 Digital Camera
My camera won't charge, i plug it into the computer throught the USB & the camera lights up like it's actually charging but after a cpl hours I took it off the USB & as soon as i cut it on it cuts...
The C1033 does NOT charge batteries. By plugging it into the computer you've actually drained the batteries faster since the camera has to spend juice communicating with the computer (even if only to say it has nothing to say). Put in a fresh set of batteries, and next time don't leave it connected to your computer.
Mar 26, 2011 | GE C1033 Digital Camera
How do i charge my camera?
You can charge the Olympus Tough 3000 / Stylus Tough 3000 by both AC adapter wall plug and via USB using your computer.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 01, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
My Nikon Coolpix S3000 says battery exhausted, but when I plug into charge it won't charge. Any suggestions?
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Jan 14, 2011 | Nikon Coolpix S3000 Digital Camera
I plugged my camera into my computer with the usb cord and its completely died. its not charging what do i do????
The camera does not charge via the USB connection. Connecting the camera to the computer drains the battery faster, as the camera has to communicate with the computer (even if only to say it has nothing to say). To charge the battery, take it out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
Dec 17, 2010 | Sony Cybershot DSC-S950 Digital Camera
My nikon coolpix S220 wont charge. I had to buy another USB connector because my son lost his and it does not seem to recognize the camera at all and will not charge
The camera does not contain any charging circuitry and will not charge the battery when connected via the USB cable. In fact connecting via USB actually drains the battery faster because the camera has to communicate with the computer (even if only to say it has nothing to say).
The camera comes with a separate MH-63 charger. Take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet. Once the battery is charged, you can put it into the camera and try connecting it to the computer.
Better yet, don't connect it to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
BATTERY DOES NOT CHARGE Received a "Vivitar T328" camera yesterday. Inserted the supplied battery and a new memory card into the camera and connected the camera via "USB" cable to the supplied charger....
How old is the battery? If the battery is refurbished or old it might just not charge anymore.
Also, do you have a separate charger for the battery? Many cameras do and that is how they charge, not when the battery is still in the camera.
Apr 09, 2010 | Vivitar ViviCam T328 Digital Camera
Need to charge battery
You can not charge camera DSC-W120 battery with USB cable in computer. To recharge battery you need battery charger with following part number..
148017521 CHARGER, BATTERY (BC-CSGC)
Available in Sony Accessories Store.
May 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
It wont charge when i plug it in or will any lights come on nothing happens at all
The S210 is a camera, not a battery charger. In order to charge the battery, remove it from the camera and insert it into the supplied battery charger.
May 01, 2009 | Nikon Coolpix S210 Digital Camera
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
