Question about Microsoft Xbox 360 Console
The tray opening problem
I had that problem i replace the snake motor and it worked
I had that problem the door opening i replace the snake motor and it worked
Posted on Jan 05, 2009
Cannot open the disc tray
If you hear the motor trying to work then try to push the disk out by try holding the eject button for couple of seconds or press it and hold it couple of times real quick. If that works you need to leave disk in it in order to get the disc tray to keep ejecting I a have cdrom that works like this. If not take it apart and take out the cd you need and replace the disc tray with motor that works.
Nov 28, 2013 | Magnavox DV220MW9 DVD Player VCR
Hp laserjet 4250dtn tray 2 & 3 will not lift
Any message appearing? like 60.X ? '*Open 'tray two' check 'open message (if No check switch 102) YES '*remove tray2 lift drive mechanism(RM1-1074-000CN) check is it working? YES '* check tray mechanism is it engaging to the lift mechanism? '* check connector/cable of lift drive motor* if not working replace lift drive mechanism '* mechanism is good replace DC controller.
RM-1074-000cn
Sep 06, 2011 | HP 4250dtn Monochrome LaserJet Printer
The tray will not open,have tried to pull it open,but get message saying,"tray error"
in this case your cd player is absolutely ok just motor of tray has damaged just open your cd player and replace dc motor you can buy it from any electronics equipment shop..just read the specification which is written on motor and then buy it...
Mar 14, 2011 | Audio Players & Recorders
How do I put on a new cerpinteen belt
there is a little sticker on the cross rail above the radiator. It has a picture of a long wrench
being applied to the tensioner in order to release tension. You will need a wrench to do that. Try all your open end wrenches until you find the right one then rig an extension for it. hose clamps and a pipe or a broom stick may come in handy.
Now you can either spend a day trying to snake the new belt down and around the lower crank pulley, or you can spend an hour and pull off the right front wheel and remove the service panel behind the wheel in the wheel well. With that panel off snaking the new serpentine belt is a snap and you need someone to hold it in place while you move the tensioner, he puts the belt on, and you release the tensioner. Now while you are in there with the service panel open, as the car is 14 years old, you might want to replace the tensioner itself and the right side "dog bone" motor mount. They both tend to also go bad with age and use and both come out with two bolts. Once you have mastered the right dog bone, you can pull the battery tray and do the one on the driver's side. the bolts which hold the battery tray on are undone through the left front wheel well.
Oct 20, 2010 | 1996 Saturn SL
CD tray does not operate
More than likely a belt which runs from the load/unload motor to the CD tray. Replace this and everything should work. I've done dozens of them. Unless you are pretty handy with electrical components I'd recommennd a repair shop. A straight forward repair If it's the problem I described, about 40 minutes work if that.
Just make sure there isn't a disk caught up at the rear of the tray. If you are missing a CD that's possibly where it is. That could be stopping the tray from opening.
Apr 07, 2010 | Sharp MD-R3 3-Disc CD Player
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
Dvd tray wont open or close
@PrimePub : Have the tray replaced by manufacturer or ask manufacturer to ship one to you.
@at_viper : If still under warranty (i think so if only 3 months old) just contact your vendor about it.
Jan 13, 2009 | Philips HTS3450 System
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Dvd recorder goodmans door sticking
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Sep 07, 2007 | Televison & Video
Microsoft Xbox 360 Console Logo
205 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
