Changed heating element and no heat and motor not turning
SOURCE: Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
SOURCE: estate dryer electric, heating element gets hot but motor does
shut off power to dryer. take front off dryer,remove belt from motor and idler pully (if there is one) try turning the motor shaft by hand. if it doesn't turn ,take off back of dryer and remove blower housing and see if anything is blocking the impellers.. if not any of these then you may have to get professional help it may be a bad motor or timer
SOURCE: Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
SOURCE: Maytag performa dryer PYE2300AZW
my dryer was working perfectly fine, but I think i had way too much laundry this day. anyhow, it just stopped working. the weird thing is the timer still runs I turn it to 90 and then it stops at 0. WEIRD!! i had my dad and husband take it apart, but of course we are reading the blueprints and tring to find matching numbers but no can do. we give up. HELP
sign the Dryer Monster
