Question about Campbell Hausfeld 26 - Gallon Air Compressor
I have a CH Model WL611701 air compressor that will only get to 20psi after about 5 minutes of running and then will make knocking noises. Any suggestions?
The pump does get rather warm. I removed the exhaust tube from the tank and the pump worked well without overheating. When i reconnect however, it takes about 5 minutes just to get up to 20psi and then the knocking sound appears. Thanks for your suggestions.
  • 1388 Answers
SOURCE: Compressor will not start
It is a good sign that the motor turns freely with and without air. That indicates that you have good bearings and that the intank check valve is in good condition. Next you should check the capacitors and the condition of the windings. Some motors have start and run capacitors and others only have run cap. Remove from the circuit and test with meter having cap. test setting. Most shops will test them for free. The cap should test within 95% of stated ( uf ) value. Replace as needed. Finally check that the flyball switch at rear inside of motor is functioning correctly. At rest, switch is at start winding, then a split second after start, it shifts to run winding. Check contacts are not stuck and that switch is working and lastly that the winding are the color of new penny. Good luck.
Posted on Jan 06, 2009
  • 582 Answers
SOURCE: My compressor shuts off by itself after running a
SOUNDS LIKE THERE COULD BE DIRT OR RUST IN THE RELIEF VALVE REMOVE AND CHECK FOR OBSTRUCTIONS RELIEVE ALL PRESSURE BEFORE DOING THIS. SHOULD BE A DRAIN **** ON THE VERY BOTTOM OF THE TANK
Posted on Aug 16, 2009
ollie reece
  • 1167 Answers
SOURCE: Husky Air Compressor has rattlling noise!
buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Posted on Nov 16, 2009
  • 15180 Answers
SOURCE: my campbell 2 gal quiet air compressor stop
valve or internal compressor motor failure crack open fitting between compressor out put and regulator if no pressure than failure in compressor if pressure regulator needs repair or replacement
Posted on Mar 02, 2010
  • 15 Answers
SOURCE: husky 26 gallon air compressor runs but will not
replace the valve plate
Posted on Mar 19, 2010
Air compressor makes loud knocking nois when running
remove shroud and see if fan is broken but may be piston is shot
Apr 10, 2013 | Craftsman 33 gal Air Compressor 6 hp...
Air conditioner compressor will not turn off.
The low pressure switch cuts power to the compressor if the pressure drops below 20psi such as when the system is low on freon.
If the compressor runs with the HVAC system in the off position, you would check for a stuck relay, or a short where the compressor clutch is getting power from another source.
Feb 26, 2013 | 2002 Mercury Grand Marquis
I have a 21 gallon 4hp peak motor Central Pneumatic oil lubricated Model 47065 air compressor and it will not go to over 20 psi and it will just keep running
Possible that there is leak on the system or the piston/rings/cylinder has worn out.Also check for oil within the unit. Check the compression of the cycle and if this is too low it means that there is wear and tear and will require a overhauling and reset.
Mar 14, 2012 | Air Tools & Compressors
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Compressor will not build pressure
Have you tried adjusting the pressure regulator / also make sure that the over presser blow off is pushed in not popped/ do you hear air leaking ?
Apr 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
After an electrical storm knocked out the electricity for a few minutes, the airconditioner unit (LG inverter) has been flashing "CH" and "05" alternately. I've tried turning it off and then on again, but...
Hi; Try turning it off for 10 min. Then turn on and remember codes. I hope You still have a user manual You can sometimes find conditions exist with Your codes...Usually after a sudden loss of voltage the compressor will go into a time out so freon pressures can equalize...Thus not puting an excessive load on MR. COMPRESSOR...
Jan 20, 2010 | Heating & Cooling
I ran my up-right 5hp compresser out of oil. will
YA YOU CAN DO YOU HAVE A OIL LEAK LD CK THAT IF YOU NEED PATR NUMBERS SEND ME THE MODEL NUBERS AND ILL GETEM FOR YOU AND TELL WERE TO GETEM
Oct 22, 2009 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
