Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Malibu Lighting ML300RTW Transformer Motor
I have a ML300RTW transformer that doesn't have enough force or strenght to turn off my lights. I wonder if there is a Potentiometer were I can increse the current going to the little motor. The motor works fine, and the time rotor keeps moving, but when the actuator reaches the swith pole, it gets stuck there and doesn't turn the system off.
  • Luciano Pedroza Nov 05, 2012
    Good morning/Thanks,
    Thanks you much. I already soved my problem. It's true, the motor is loosing It's strenght, So I opened the switch which is activated by the litte gear motor. Y cleaned it, lubricated it and decrease the tension on the contacts to mke the switch lighter. Now my lights turn on and off. Thanks to all and have a great time.
  • Intermatic Master
  • 5,089 Answers
Motor has gotten weak, and is overheating and soon will not work.
Some people report taking apart motor and cleaning gears.
Others report that they didn't record how the gears came off, and can not reassemble.
PB912M10 Clock module is not sold separately.
Switch power pack to override so lights are ON, and plug transformer into cheap wall timer.
Copy following link for tips to get power pack to last longer, troubleshoot, and warranty, etc.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Nov 05, 2012
  • 4088 Answers
SOURCE: One year outdoor lighting (300V #135708) Transformer not working
You need to disconnect the lighting load completely from the transformer and check it's output. If it is dead unloaded, replace the transformer. If it seems to work now, then some part of the lighting circuit has probably shorted out. If there are several circuits coming to the transformer, attach each one separately and recheck for power. When one is attached that kills the output, investigate that circuit. Check for any broken lamps first, then the wiring must be opened at each lamp location to check for a local short circuit. A somewhat tedious fix. Hope this helps!
Posted on May 24, 2010
SOURCE: Malibu transformer shuts down early
I'm thinking that a better brand is in order. Mine shorted out and started a fire. Luckily we had just returned from vacation and put it out with a hose.
Posted on Sep 05, 2010
SOURCE: I have a ML300RTW Malibu
You can buy cheap plug-in timer, set power pack to override and then plug power pack into cheap timer.
Otherwise there are no repair parts for power packs other than on-off trippers.
Power packs come with 5 year limited warranty, so you are within warranty period. Good job saving the date of purchase, you outshine with that detail.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 02, 2011
SOURCE: I have a Malibu 300
I don't know any site selling power pack gears.
Maybe ebay has gears or sells used power pack.
Easiest thing might be buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Intermatic does not sell the timer module separately, or the gears.
Posted on Aug 13, 2011
  • 5089 Answers
SOURCE: Malibu transformer ml44p doesn't turn off
Check if trippers are worn.
Check if dial rotates and keeps good time.
Plug transformer into cheap wall timer.
Copy following link for trippers, 5-year warranty info, tips to make power pack last longer, and other troubleshoot resources:
Posted on Oct 31, 2012
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
Mar 26, 2016 | Intermatic Malibu 300W Power Pack...
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.
ML300 series transformers make sound.
Used styrafoam to separate transformer from contact with building so sound is not carried.
These transformers have 10 year limited warranty.
Copy following link for general troubleshoot and tips, and warranty information, and trippers.
Oct 23, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
My Malibu ML 300 RTW has stopped working, but I can hear the timer. No lights come on, though.
Sounds like the transformer died which isn't uncommon. One cause is overloading the circuit (too many lights) figure out the total wattage by adding the bulb watttage usually 11 by the amount of lights you have. I would buy a transformer with around 200 Watts higher than you need to allow for expansion and the transformer wont have to "work" as hard.
Aug 28, 2011 | Intermatic Malibu 300W Power Pack...
I have a Malibu 300 watt ML300rtw transformer for outside lighting. The timer stopped moving and when I took it apart the small plastic gear was worn down and it was not turning the timer. Is there...
Aug 13, 2011 | Intermatic Malibu 300W Power Pack...
I have a ML300RTW Malibu transformer (S/N ML300RTW) that I bought 7/31/08. I'm pulling 170 watts from that transformer. I purchased new trippers from Northern Lights Electrical Supply. I have replaced...
Apr 02, 2011 | Intermatic Malibu 300W Power Pack...
May 24, 2010 | Intermatic Malibu 300W Power Pack...
Malibu landscape lighting transformer problem
Testing ohms across A and B will read open circuit through transformer coil.
Testing DC voltage across terminals A and B should read 12 volts DC, and nothing less.
Transformer should make humming sound when working.
Test that receptacle has power and breaker is not tripped.
There are no repair parts for power packs, but they come with 5 year limited warranty.
May 30, 2009 | Intermatic Malibu 300W Power Pack...
Malibu landscape transformer
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
309 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
