Question about Intel Motherboard
Unable to access the internet
I bought an Intel mother board and a dual core 2 (2.2Ghhz) processor.
To the pest of my knowledge everything is working except the internet.
when i connect the cable it recognizes it but i cannot lunch any site or page
  • Chris Dawson May 11, 2010
    What operating system are you running, and do you have any third party software installed that is supposed to control the internet connection?
  • 34 Answers
If you're using WinXP, then what you may first want to check for is to make sure that there is no exclamation point in device manager. START/CONTROL PANEL/SYSTEM/HARDWARE tab/then Device Manager. Then look at Network Adapters, if there is no exclamation point, then go into NETWORK CONNECTIONS. START/MY NETWORK PLACES/ then on the upper left hand side click on NETWORK CONNECTIONS, make sure it says connected. you should see your Local Area Connection under LAN-HIGH SPEED INTERNET. Then right click on the connection goto Properties under the General Tab click on Internet Protocal(TCP/IP) then click on properties. Make sure that you're not using a static IP address if so just click on Obtain an IP address automatically and the same for the DNS below.
Posted on Jan 22, 2009
    Problem Solver:
  • 5 Answers
Please Test Ethernet Card
Posted on Jan 07, 2009
Does my pc that is intel pentium dual core e2140 @1.60ghz have pci express?? Can this processor support graphic cards like nvidea 9500gt 1 gb??? or any other cards???? plse reply fast
Graphics support is mainly determine by the mother board. based on the processor you have that mother board should be equipped with a PCI express slot. in that case YES it is Supported. make shure you follow installation instructions and check that you have at least the minimum power supply requirements for the card 380W or above.
Best of luck
Jun 01, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
I have a DG965RY mother board can i install a 1.6 daul core on that board and download windows7 and will it work
Yes, you can install a Pentium dual core processor on this mother board. Below is a complete list of the compatible processors for this motherboard:
http://www.cpu-upgrade.com/mb-Intel/DG965RY.html
Windows 7 will also work with this motherboard. Just make sure that you install a minimum of 2GB RAM for you to take full advantage of Windows 7's Aero feature.
Mar 23, 2011 | Intel DG965RY Motherboard
This mother board support dual core proccessor
This motherboard is built with the Intel 845 chipset and is socket 478. This particular motherboard will not support a dual core processor of any kind. This board will only support a standard socket 478 Pentium 4 processor at best. I do not know of any that will support anything better than a Pentium 4 2.8GHz processor with a 400MHz F.S.B.
Oct 19, 2010 | Intel Desktop Board D845EPIL Motherboard
Is DG41RQ mother board suitable for present Intel Pentium D Dual Core processor E 800 with 3.4 MHz, and Socket LGA775. The name of the processsor is costerica and its bus speed is 800. Model says 945XL...
Yes this motherboard will definitely work with that processor , since this one can support up to a Quad core processor. <br />Here is the complete details specs for this motherboard.<br /><a href="http://www.technology.am/intel-dg41rq-motherboard-233414.html">http://www.technology.am/intel-dg41rq-motherboard-233414.html</a><br /><br />
Aug 24, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
I have not vga(video) drivers.....pls help me
we can use three type of mother board on dual cpu. that are 865 chipset , 915 chipset , 945gz chipset, u can download thease driver from intel . enjoy good luck. plzzzzzzzzzz vote me for increase my rating
Jul 28, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
I am from INDIA... i want to buy i IBM
Hi Friend,
Check below the model numbers of the intel dual core mother boards avaliable and the
address where u can buy it in Chennai,
1.Intel Atom 330 Dual Core (2x 1.6Ghz)
a.Intel D945GCLF2 mini-ITX
Features are:
  • Dual Core Atom CPU
  • TV-Out (S-Video)
  • 4x Rear USB 2.0
  • VGA, Serial and Parallel
  • 1x DDR2 533/667 RAM
  • 1 x Gbit LAN
  • Realtek High Definition Audio
  • Power: 24 Pin ATX, P4-connector
  • RoHS compliant
b.ECS P945GC
Feature are:
  • custom design board using mini-DTX form factor up to 170×170mm.
  • Intel 945GC and ICH7 chipset Intel Atom 330 CPU dual-core 1.6 GHz, 2×512KB (1MB) of L2 cache
  • FSB 533MHz system bus support up to 1×2GB (DDR2 533/400)
  • Integrated Intel Graphics Media Accelerator 950 ( GMA950 )
  • 2 X SATAII and 1 x IDE channel (for 2 IDE devices)
  • VIA VT1708B 6-channel High Definition audio CODEC
  • 10/100 Fast Ethernet LAN using ATHEROS AR8012 10/100 Mbps PHY
C.Jetway NC92-330-LF
Features are:
  • INTEL®945GC + ICH7 Chipset
  • Support INTEL®Atom Dual-Core 330 CPU
  • Built-in INTEL®GMA 950 Graphics Core
  • Supports 1x Gigabit LAN
  • Integrated ALC662 HD Audio CODEC with 6-CH
  • ITX Form Factor(170mm x 170mm)
  • Support Daughter board Expansion
D.Foxconn 45CSX / 45CTD (soon to be release)
Features are:
  • Intel® AtomTM dual-core 330 processor mounted on board
  • 533 MHz (FSB)
  • DDR2 533 MHz x 1 DIMM, Max. 2GB
  • 1* PCI
  • 2* SATA II
  • 5.1 channel HDA, Realtek® ALC662
  • 10/100M LAN, Realtek® RTL8100C
  • 6 USB 2.0 ports
These are available in India with Prices and best in India Industry
Intel Dual Core Price list in India
  • Intel E2140 Dual Core Processor - 2100/- Indian Rupee
  • Intel E2160 Dual Core Processor - 2450/- Indian rupee
  • Intel E2180 Dual Core Processor - 2800/- Indian Rupee
  • Intel E8500 Core 2 Duo Processor - 8200/- Indian Rupee
  • Intel 2200 Pentium Dual Core 2.2 GHZ -3400/- Indian Rupee
  • Intel E4600 Core 2 Duo Processor - 4990/- Indian Rupee
Address
Address:88/150.Nelson Manikam Road,Dharma Tower Ground,Floor7&8,Choolaimedu,Chennai-94
Landmarks : Near Nungambakkam RailwayStation / Loyala College /Metha Nagar Bridge/Opposite to Bank of Baroda/Mobile Store/ Indian Terrain Ready made
Contact Number:98402 72809
For future assistance kindly contact fixya
Regards,
Ayyasam
Jun 26, 2009 | Abit AS8 Motherboard
I didnt have motherboard cd so plz help me how can i get that. i can not asscess internet on my system. so plz reply me as soon as possible. thanking you
Tell the manufacturer name of the mother board
i will give u the download link. download it from another pc having internet and install it in u r pc.
if it helps
pls Rate me..
Jun 25, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Unable to install turboc++ in new mother board with 2.0 dual core
If I were you, I'd use dev-c++ or MS Visual C++ exprees, both are freely available on the Internet and are excellent IDE's for programming in C++.
Dev-C++: http://www.bloodshed.net/devcpp.html
Visual C++: http://www.microsoft.com/express/vc/
Dec 08, 2008 | ASUS P5PE-VM Motherboard
Intel processor E2200 LGA775 not working
This motherboard supports Intel single core Pentium 4/ Celeron processors, according to the asus website.
So your dual core is not supported.
You need to get a intel pentium 4 or celeron processor
Apr 04, 2008 | ASUS P5RD1-VM Motherboard
Intel Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
