Question about Fellowes DM8C Cross-Cut Shredder
Fellows model 38933 DM8C shreeder has a broken gear housing (outside half) is a replacement part available
Motor runs but will not pull paper into the cutters. Was making a loud thumping noise intermittently before it quit shreeding. White outside half of the drive gear housing is cracked open to the point where the gears are visable. Is it likely the housing only or the gears as well?
Huty
  • 17 Answers
SOURCE: shreeder broken
Here you go buddy http://www.fellowes.com/Fellowes/Materials/Documents/ps60-2_60c-2_2005manual.pdf
Posted on Aug 29, 2007
t_vinson57
  • 58 Answers
SOURCE: broken....
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
JayBlair
  • 328 Answers
SOURCE: The wheel furthest from the drive motor doesn't turn.
Most parts are available. But probably have to buy whole cutter asm.
Posted on Jun 22, 2009
  • 32 Answers
SOURCE: I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Posted on Aug 31, 2009
  • 610 Answers
SOURCE: the gears have broken off on the schredder
call Fellows at 1-800-955-0959.
Posted on Nov 25, 2009
P-45c shreeder motor runs but blades do not turn got all paper out but still do not turn
David,
More than likely, you have stripped the plastic gear inside. Those gears can sometimes be difficult to find and purchase. I would suggest trying to open up the top so that you can confirm if the gear is stripped. I would also suggest not putting as much paper through the shredder as they say it will handle. Hope this helps!
May 20, 2015 | Fellowes Office Equipment & Supplies
I have the Royal SC120 model. The shredder does
1 or 2 gears are broken. royal doesn't make many replacement parts for their machines, might try calling royal at 1-800-222-2310. I would recommend replacing unit with a Fellows brand shredder. royal also makes Ativa brand- don't buy it either.
Dec 11, 2009 | Televison & Video
I have a DM8C that only runs for a couple of seconds at a time and then it stops. Toggle the switch back and forth and it feeds a little at a time until the page is completely shredded. It works okay in...
Common solution is to clean upper and lower sensors with cotton swab. If it still jams, then you will have to remove the top carefully and clean all paper shreds out of the housing. The paper shreds are most likely packed in the housing shroud and jamming or overloading the motor.
Jun 21, 2009 | Fellowes DM8C Cross-Cut Shredder
Jun 17, 2009 | Fellowes DM8C Cross-Cut Shredder
Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Mar 13, 2009 | Fellowes OD700C Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
May 16, 2008 | Fellowes DM8C Cross-Cut Shredder
Fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Mar 29, 2008 | Fellowes DM8C Cross-Cut Shredder
Shreeder broken
Jun 20, 2007 | Fellowes PS60-2 Shredder
Fellowes DM8C Cross-Cut Shredder Logo
194 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
