How to remove glass on instaflame fireplace dv36rn, i have no manual
Where can i get a thermocouple for my Instaflame DV34RN gas fireplace?
Home depot . lowes, rona , home hardware. Honeywell universal should do it .
Oct 10, 2017 | Heating & Cooling
Why does my instaflame model z50 gas fireplace not ignite when i push the electronic switch?
Electrode might need cleaning , pilot might need a clean , electrode might be out of position.
Nov 05, 2016 | Heating & Cooling
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
Mar 02, 2016 | Heating & Cooling
Gas fireplace wont stay lit- it is a sealed unit so can taccess the pilot or gas holes in the logs. is it safe to remove glass panel?
Yes, removing the glass is safe, if you do it carefully, so as not to break it. Put it well out of your way, after removing it. In fact, removing it is the only way to access and service the Pilot Assembly and the Burners.
If the pilot won't stay lit, there are several things that can cause this on a Direct Vent Gas Fireplace:
  • The direct vent on the outside of the house is block or clogged.
  • Wind is blowing back through the direct vent, blowing out the pilot.
  • Low gas pressure
  • A dirty pilot.
  • The thermocouple and/or Thermopile (part of the pilot assembly) has failed.
If you can provide me with the make and model number of your gas fireplace, I may be able to furnish you with an Owners Manual, that will help you to continue to troubleshoot the problem.
Hope this helped you.
Apr 29, 2011 | Heating & Cooling
Manual for instaflame gas fireplace
how to you take off the front glass cover to clean it
Nov 02, 2010 | Heating & Cooling
HOw do I clean the inside glass of my fireplace?
The decorative surround of your fireplace should easily be removed (if it is anything like mine) and you should then see a number of fixing screws which hold the glass in place.
Remove these and the glass will come out (take care not to let it fall).
Jan 05, 2010 | Watches
Montego gas fireplace
There is a product that I use when servicing gas fireplaces that works pretty good. Google search "Rutland White Off". In a lot of cases it takes just about everything off and the glass looks brand new. If it went to long without being cleaned, it could be permanently baked into the glass. As far as removing the glass, every manufacturer uses there own style of clip. Check around the bottom of the fireplace where the controls are for a latch or possibly screws that are holding it in place, sorry, without looking at it, it's pretty hard to answer that part of your question
Jan 11, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
