Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
It can be replaced. Here's a link to your manual for the dryer, which on the 2nd and 3rd pages has a diagram of it and a part number for you...when you have your part number you can order it either directly from Electrolux or find one on Ebay or another online source....if you have a local appliance shop you may be able to get one there as well....here's the link:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/5995396412.pdf
Posted on Nov 04, 2012
SOURCE: Sears name:model 417.44102300
its glued on take a razor blade and carfully cut the glue between the front panel and the boot
Posted on Sep 10, 2007
SOURCE: dryer comes on for a few minutes, makes horrible
It could be the belt was partially broken, and as it came apart causing the dryer to no longer start,,, it made the noise your talking about. If the dryer still heats up, and you can hear the motor running,,, these would all be signs toward a broken belt.
Posted on Mar 13, 2009
SOURCE: Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Posted on Oct 04, 2009
SOURCE: FEX831CSO dryer stopped heating mid-cycle
Apr 22, 2010 My dryer would not dry the clothes either. the heating element would only come on once then nothing. The high limit thermostat was bad. Pull the electrical plug. Remove the top cover and the thermostat has an orange/black wire to it. It is hard to get to the screws but I was able. Then I found the element would cycle many times but not stay on long enough to dry the clothes thoroughly - I found the culprit - the motor driven fan creats a suctionin the drum and the hot air from the rear coil is pulled thru the drum, thru the front door (via the holes in the door's inner face) down thru the lint screen, thru the outer fan housing and out the exhaust. My problem was that the door's cardboard backing had seperated and along with the trapped lint clogged the door's holes and restricted the air flow. I took the door off, seperated the 2 halves, removed the cardboard and cleaned the lint out. The dryer is now working like new. Summary: The high limit thermostat was bad probably from cycling so much and the air flow diminished slowly over time to the point I did not notice until the clothes just wouldn't dry.
Check the air flow first.
Hope this helps
See less
Posted on Apr 22, 2010
SOURCE: The dryer on the stackable FEX831CS unit is making
Your rear bearing is bad and needs to be replaced. Trust me, it isn'e easy to get to either.
Posted on Nov 26, 2010
Sep 20, 2014 | Dryers
Apr 08, 2014 | Dryers
Jun 16, 2012 | Washing Machines
Apr 01, 2011 | Dryers
Jun 25, 2010 | Kenmore Dryers
Apr 11, 2010 | Frigidaire Dryers
May 15, 2009 | Kenmore Dryers
Apr 10, 2009 | Dryers
Jan 23, 2009 | Frigidaire GLER642A Electric Dryer
Dec 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
143 people viewed this question
