I have a laptop acer aspire 5741 and its keeps turning off by it self, i did clean the fan from the dust but it still the same problem, so please tell me what should i do else :'(
  • 7,627 Answers
Try a Laptop Cooler with a couple fans, Is the laptop setting on a soft surface restricting air flow? If so elevate it so there is sufficent room for air to cilculate.You may have to open the laptop and thorough cleaning. Otherwise you may have a bad component.
Posted on Nov 04, 2012
  • 18 Answers
SOURCE: to know how to disassemble my acer aspire one
Here's the complete disassembling procedure...
http://erkinson.altervista.org/acer-aspire-one-532h-aggiornare-ramhdwifi-smontare-lcd/
google translate it
Posted on Nov 02, 2010
babes_ganda0
  • 381 Answers
SOURCE: Acer Aspire 3003LCI Laptop Fan starts but stops after 5 seconds
remove the memory then make a clean or replace a new memory
Posted on Jun 25, 2009
  • 42 Answers
SOURCE: ihave an acer aspire one mini laptop with webcam
Linux or Windows version? If Windows, go to START, SETTINGS, CONTROL PANEL, SCANNERS AND CAMERAS and click on the USB Camera icon or download and run SKYPE.
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Posted on Jul 14, 2009
SOURCE: My Acer Aspire 5542 laptop
my laptop get overheating for cooling what required..... please tell me............????????
Posted on Apr 01, 2011
Intel hm55 acer aspire 5741
It is difficult. You need to read the Acer Aspire 5741 Service Manual.
Feb 27, 2014 | Computers & Internet
Acer aspire 5741 overheating then it shuts off
heck to see if the fan is working, if not replace it.If the fan is working and spinning freely, then clean the vents and remove any dust/lint.You may need to remove the fan/heatsink off the CPU and clean off the old heatsink compound and replace it with fresh heatsink compound and reinstall the fan/heatsink.
When using the laptop, make sure it is on a firm flat surface and none of the vents are obstructed.
Oct 23, 2011 | Acer ASPIRE 5720-4649 Notebook
My acer aspire turns itself of after about 30min of using
Usually,, something like this is caused by a heat problem.
Things that usually heat up in the laptop are:
- the CPU (check the fan, may have to take apart to really clean)
- the Video Card (this may have a fan but usually a heat-sink, also may be dirty and full of dust)
- the RAM (usually nothing much to do here)
- the Hard Drive (this may be the problem but check other things first)
I would check the following forum as they describe how to take it apart for cleaning and also refer to a "build up" of dust in this laptop model.
http://www.avforums.com/forums/laptops-netbooks-tablets/1057228-acer-aspire-7720-turns-off.html
Another thing would be to check the BIOS version and also check at what levels the alerts and actions are set.
Also, when using a laptop - do not cover the fan vents which may be underneath.
Good luck
Feb 27, 2011 | Acer Aspire 7720 Notebook
Acer aspire 5520 keep shutting down also will not start
Well, I know the solution to your problem...But I'm not going to tell you!!
Just kidding...
Problem: CPU becomes very hot as result laptop shutdown.
What is the solution then?
Simple, just remove the dust from the cooling mechanism by the fan.
Dec 27, 2010 | Acer Aspire 5520-5908 Notebook
Hello, i have a acer aspire 5735 laptop and it overheats... i checked the vents and i cant see through it..... please help
Most of the time laptop overheats due to the accumulartion of dust on the vents.
You can clean it by blowing a can of compressed air into the vents and thus cleaning it.
Still if it continues to overheat- please elevate the laptop properly i.e work on it keeping it on a hard surface so that there is proper passage of air from the laptop.
Lastly make sure that the fan beneath is running properly i.e - you can hear the sound of the fan.
Hope this much will work.
Dec 21, 2010 | Acer Aspire 5735 Notebook
Acer laptop gets hot and turns off-acer replaced one fan under warranty. Still have prob. but war is out
Here's a link to how to clean your cpu cooling fan. The system does shut down due to a thermal cut off, so you want to keep the heat down. Use compressed air on all the air slots. Also open up the bottom and scrape the fan of dust, or whatever if dirty. If the fan doesn't come on you can get one online. They're fairly inexpensive.
http://www.insidemylaptop.com/clean-cooling-fan-acer-aspire-3003lm/
Here's a fan purchase outfit. Use this link. If you don't see your system, give them a call as the 6530 may use a fan that's the same in another acer model. The vendor should know.
Acer Fans:
http://www.impactcomputers.com/acer-parts-internal-parts-and-assemblies-cooling-fans---heat-sinks.html
Main page Impact Computers and Electronics:
good luck.
Jul 21, 2010 | Acer Aspire 6530-5143 Notebook PC
Why does my laptop keep turning off in middle of programme
Your laptop could be overheating, due to dust buildup in the fan. You can try some compressed air to blow out the dust that builds up, over time, in the fan. I also use a small fan I bought at Walmart, and let it blow over the fan area (you will be able to tell where it is by feeling the computer, and noticing it to be hotter in one area than others). You didn't mention what program it's turning off in the middle of, and, as a last resort, you might have to reinstall that program, if cleaning the fan with compressed air doesn't work. Good luck, and hope this helps.
May 27, 2010 | Acer Aspire 5315-2940 Notebook
My acer aspire 5590 laptop are always overheated and shut down easily
Ok as a workaround, get your self a laptop Cooler pad, real inexpensive these have extra Fans and keep it real cool, check dust hasn't clogged up the outlet.
Feb 21, 2010 | Acer Aspire 5500 5570-4421 Laptop
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
