Question about Music
Schematic for phonic peq 3300 - Music
  • jon kay
    jon kay Nov 05, 2012
    I repaired unit w/o schematics and ran it several hours on test bench sounds great !
  • 47 Answers
Could not find a free one online but did find a PDF download for 10 Euros at the folllowing website: http://home.versatel.nl/manualswarehouse/manuals.htm
use the menu on the far left hand side to scroll to Phonic and then to peq 3300, then select pdf to download it.
Posted on Nov 04, 2012
What is the meaning of phonetic and phonic
Phonics is the term used when physically looking at speech vs sound and Phonetics is the study of speech sounds! Hope that helped! The Difference Between Phonics and Phonetics
Dec 05, 2016 | Phonic Music
Phonic powerpod 820 schematic diagram
This site might help you out ?
http://elektrotanya.com/phonic_max860_1500_2500_right_side_poweramp_sch.pdf/download.html
Feb 27, 2015 | Phonic Music
My power supply in my phonic helix mkII 24 board is blown, it was messed up in a power surge, I have tested the remaining connecting parts and everything else is fine. I contacted phonic and they dont...
Usually it's the electrolytic caps that go in those, they basically "cook" and dry out, a power spike just pushes them over the edge. I've also had this problem with mine & 2 12 volt switchers for my HD and for the satellite had the same fix. I added a fan which helps. Another solution is to go to a second hand store, find 3 power suplies (15v,15v, 5V) and put them in place of the existing one. I am considering that myself as the firewire packed it in again last month and I had to jump over to the other 5v regulator to get it going again, even tho it was only 0.2 v short! Cheers, Sandrine
Jun 20, 2011 | Phonic Helix18fw 18 Channel Mixer with...
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
Phantom power will not wor on my phonic 620 cd jacks will work but when i plug in a mic it will not work help
I assume you are using CONDENSER microphones, as these are really the only ones that can use Phantom power. Also do NOT use any MONAURAL connections to MIC jacks while using Phantom power.
Dec 12, 2010 | Phonic NEW PHONIC SONIC STATION 22 MIXER...
Music Logo
233 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
