Question about GE Profile JGS968 Gas Kitchen Range
Controls are locked
It says to hold button for 3 seconds tried start button no success
    New Friend:
You must hold the '9' and '0' buttons down simultaneously for 3 seconds.
Posted on Aug 11, 2013
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
How is to enter dfu mode
Press power button for 5 seconds, then, without releasing power button, press home button for 10 seconds. After that release only the power button, leaving home pressed, for 15 seconds. That should do it.
If you need help, use redsn0w as a guide.
May 25, 2013 | Apple iPhone Cell Phones
Machine powers up,,,than the whole machines powers down
Let's see if we can get it into diagnostic mode and check for any fault codes. Make sure the dryer is in standby mode, plugged in with all the indicators off. Select any button except the PAUSE/CANCEL button. PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS. If test mode was entered successfully all indicators will illuminate for 5 seconds with 88 showing in the two digit display. If there are no saved or active fault codes all indicators will momentarily turn off then stay on with 88 in the display. If there are any fault codes, the most recent one will alternately show F- and "XX " where XX is the fault code. and all the cycle indicators will flash. If you can't enter the test mode try a different button. Lets start there.
Nov 17, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
How do I reset my SMC barricade g router?
hi Eric,
To Reset the newer Barricade Router, use the RESET button on the Router. It is found on the rear panel (except 7004ABR/7008ABR, where it is found in the front). It's a small pinhole blue button. Use a paperclip / pen / pencil to hold in. Reset can be done in following ways. If you find Power LED blinking, then it indicates a successful RESET......
Procedure 1 -
Unplug all the cables except the power cord.
While the Barricade is powered ON, Hold the RESET button for 30 seconds or as long as you find the Power LED blinks.
Procedure 2 -
1 - Unplug all the cables except the power cord.
2 - While the Barricade is powered ON, Hold the RESET button for 5 seconds.
3- While holding the RESET, turn OFF the power to the Router.
4- Continue to hold it for 5 seconds, then turn ON the power to the Router.
5- Wait for another 5 seconds and then release the RESET button.
Procedure 3 -
1 - Unplug all the cables except the power cord and Power ON the Router.
2 - Hold the RESET button for 3 seconds.
3 - Release the RESET button for 2 seconds.
4 - Continue Steps 2 and 3 for Four more times.
Sep 03, 2012 | SMC Barricade g SMC2804WBRP-G Wireless...
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Reset change engine oil light
Information taken from: http://www.idavette.net/tech/oilreset.htm
[quote]
The "Change Oil" indicator is reset by using a sequence of Driver Information Center (DIC) key presses as follows:
1. Turn ignition "ON", but do not start engine. (ALDL pin "G" should NOT be grounded.)
2. Press the "ENG/MET" button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of Step 2, press and hold the "GAUGES" button. While the button is held, the "Change Oil" indicator will flash.
4. Continue holding the "GAUGES" button until the "Change Oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds.
If it does not successfully reset, turn ignition "OFF" and repeat the procedure from Step 1.
[/quote]
Nov 16, 2009 | 1991 Chevrolet Corvette
Zenith Redi_set clock radio Z230S
Describe your problem: Depress MONTH/DATE and ALARM1 for 3 seconds and display will show DST 'start' month,week,and date.
Display will show 4F 4.1, alternately flashing
4F = April First week. 4.1 = April 1.That is the old dates for change. What we want to do is to change to the new dates. Once it is done, it will change in the new dates as it did on the
old dates..
Hold down the MONTH/DATE button for 5 seconds, and while pressing the - or down button3 times, until the display shows '3'F2.
3 is month F2 is the week.
=March 2nd week.
You have successfully change the March changeover.
Now for the November change.
Depress and hold MONTH/DATE and ALARM2 after 3 second the display will show DST 'end' month,week, and date.
First digit will be 10 =month. second digit will be L=Last week, and date, will flash alternately.
While holding down the MONTH/DATE press the + or UP button once the display will show 11 (November) and F (first week) and 1 as date alternately flashing.
You have successfully set it for the next 100 years
Apr 17, 2009 | Zenith Z230S Clock Radio
I need 3 digit code for tevion universal remote control to make it work on my diamond tv or a code for one for all urc 7540 remote thank u
If you do not have a code for method one or two you can try a automatic scan. This will scan for every possible
code that the device will have.
1 – Turn on the device you want the remote to control. If you are using a VHS or DVD player please make
sure that it is playing a dvd/video before you start.
2 – Press and hold the DEVICE key you wish to program for 3 seconds. The LED will light up upon
Key press and will go off ater3 seconds ,now release the button.
3 – Press and release the PLAY button and the code search will begin. The LED flashes every one second
when a code has been successfully sent.
4 – When your device turns off, press and release the pause button on your URC, the LED will
remain on once pressed.
5 –In order to now turn your device back on press the CH – button on your URC, if it does not respond
then continually press the CH – button in 2 second intervals until your device switches back on.
6 – Once your URC is successfully controlling the device, press and release the EXIT button on your
URC, the LED will flash quickly four times and then go off.
Hope this helps.
Apr 06, 2008 | Televison & Video
GE Profile JGS968 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
