Question about Garden
CHECK COIL ON WEEDEATER
HOW TO TEST THE COIL
  • 81 Answers
Most likely the isue is too large plug gap. The proper gap is 1mm, set the gap first then if you still want to check coil output take the plug out hold the base of the plug to the cylinder head pull the start rope and look for a spark. If you can't see a spark seperate the plug base from the cylinder with your finger pull the cord, if it hurts stop pulling the coil is good! If you dont feel the shock then the coil may be defective however there is a couple of electrical conections to check first. If you already have access to the coil and have an ohm meter check for a low resistance (below 10 ohms) across the coil wires.
Posted on Nov 05, 2012
How to check coil on weedeater
Get a cheap spark checker at your local auto parts store.
Aug 28, 2014 | Troy Bilt Tb70ss Gas Trimmer
Troy built 27cc weedeater stops running after it gets hot
Check the coil with a spark checker immediately when this happens. You probably have a week coil.
Aug 18, 2014 | Troy Garden
Stihl sf44 weedeater wont fire
more info please? does it now have a spark and good compression?
Jul 27, 2012 | Stihl Garden
My weedeater has no spark at all
If there is no spark then I would suggest checking out the plug wire for cracks or breaks If there is none present then the ignition coil could be finished Take it off take it into your small engines dealer and get him to test it.
Dec 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have poulan/weedeater leaf blower
ignition coil,or blown head gasket...
Nov 08, 2009 | Poulan Garden
It keeps stalling after only a few minures
Suspect Ignition Coil is failing under heat.
To test this, take the unit outdoors and have a fire extinguisher handy. Start and allow unit to run until it shuts down. Then remove spark plug and test for spark by grounding the outer shell of the plug on the engine's metal surface.
BE SAFE!
Keep your face away from the spark plug hole as you pull the rope to test for spark. Expelled fuel or vapors can ignite via the removed spark plug or any subsequent arc.
If no spark when hot, and good spark when cold, replace ignition coil.
Find your EXACT model number on your unit, then go HERE to lookup the part number of the coil. Call your local reputable repair shop and ask if they have it in stock or can order for you.
Hope this helps.
Oct 04, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Wont start when hot
might be coil ? you can test it with and ohm meter should be within specs on both primary and secondary sides ? but try this first to see if its a vapor lock or fuel hose issue ? when it wont start get you a can of starting fluid and spray the air filter see if it restarts then ? this will tell you its fuel not spark ? then you can recheck hoses and primerbulb ? hope this helps
Aug 27, 2009 | Craftsman 25cc Gas Line Trimmer
Ght225 Weedeater hedge trimmer
try sanding the fly wheel and the coil to get the rust off
Jun 17, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
I can't get my weedeater to fire. I've replaced the coil but still no fire.
hi
perhaps your coil was not bad,check the wires at the ignition sistem
bye
Apr 26, 2009 | Craftsman Garden
Garden Logo
559 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
