Question about Technics Audio Players & Recorders
Technics cd player will not play says dvd h02 whats wrong
Will not play says dvd h02
    Master:
  • 689 Answers
It is hooch, just get a different one, It will cost you less then to have it (Repaired)
Posted on Nov 10, 2012
3 Suggested Answers
  • 3 Answers
SOURCE: CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Have just purchased a secondhand
Are you sure the TDK blank had either AUDIO/MUSIC somewhere written on the disc...if not, then that is the problem. On the other hand it it should not have recorded or played back as you said it did.
If it did have Audio/Music written on the disc, then first of all give the laser a clean by using either a disc cleaner or better still, take the cover off and gain access to the laser, using a cotton bud, diped in INDUSTRIAL METHALATED SPIRIT (usually coloured purple) do not use medical metholated spirit as oily additives could be added and smear the laser lens. Dry off the lens with the dry end of the cotton bud. Do not soak the cotton bud in the spirit, just a very small amount will do !!!
If it does not work now, try using other good named branded Audio/Music CD-R discs as there appears to be such a variation in the quality of CD discs which is well documented !
Did you FINALISE the TDK disc before you removed it from you recorder??
I have a feeling its the TDK disk.....I avoid TDK if I can...Try Sony or Philips Audio/Music discs, very few failures for me with those brands.
Hope this has ben of some help...good luck
Posted on Sep 29, 2011
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
Dvd will not play. H02 appears. Have reset to no
H02 is a fault code, though I don't know what. It code be either an electrical fault or mechanical problem. A mechanical fault might be easy to spot so take off the top cover and see if anything is broken, otherwise I suggest a service manual will come in handy.
May 21, 2010 | Denon DVD-800 DVD Player
ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Dec 01, 2009 | Panasonic Televison & Video
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
Panasonic DVD-S35 Player H02 problem
Hi, this is an unfortunate error. this is referring to the lens assembly. it is unable to scan and read at this moment. it could be because the lens is dead or, it could be that the lens is simply dirty and will need to be cleaned. i would try cleaning it with a non brush type cleaning process. Once cleaned and you still have the same issue, i recommend replacing the lens assembly.
Mar 11, 2009 | Panasonic DVD-S35 DVD Player
Technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
Technics sc-dv290
Oct 26, 2008 | Technics SC-DV290 System
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
Error message when playing any DVD in Hi-fi
Feb 28, 2007 | Technics SCHD560 CD Shelf System
63 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
