Question about Sewing Machines
My Viking Designer 2 keeps telling me it is set for pressure foot Q, I don't even have that foot. I can't use any of the decorative designs I have been using. I have no idea what I did to chan
What do I do to change the settings back to normal mode.
  • Sewing Machines Master
  • 7,365 Answers
If you have not found a solution yet, normally turning the sewing
machine off and back on again usually clears the computer part
of the sewing machine.
but if it doesn't then a trip to the repair shop may be in order
to see if there is something wrong with the motherboard
Posted on Nov 05, 2012
SOURCE: Husqvarna Viking Designer 1 Beeper
when i,m doing a machine embrody the thread will fray in the needle and spoil the whole design, i,m afaird to do anything on a piece to keep. what is the best thread to use
Posted on Feb 14, 2008
  • 192 Answers
SOURCE: Q foot for Designer 1 machine
Hold the foot in your left hand. Attempt to put the foot on, but when you begin to struggle bring the needle down through the foot using the hand wheel. Once the needle screw is lowered about 1/2 way, the ankle will easily fit onto the shank and you can put the screw in.
Bringing the needle down saves you from having to wrestle with the spring tension in the foot and take all the work out of it.
Posted on Apr 08, 2008
SewTechWayne
  • 186 Answers
SOURCE: Viking Designer 2 service mode
Hold down the start/stop button and the presser foot pivot button at the same time and turn the power on. You may need to try it a few times.
Hope that helps.
Posted on Feb 11, 2009
lintalks71
  • 7 Answers
SOURCE: Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
Posted on Jun 19, 2009
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
I have a Viking designer ruby machine. I am trying to embroider a name. I have the right hoop and the design fits the hoop and I keep getting an error message.
Sometimes machines will not work because even though the hoop appears large enough, there is not enough leeway for the presser foot to maneuver inside the hoop. This is a common issue with embroidery machines. The probably answer is to either shrink the design or use a larger hoop.
Nov 13, 2016 | Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
How do I adjust the tension on my Designer I sewing maching
Let me give you instructions on adjusting the tension for any machine-they'll apply to yours as well. I recommend you thread the bobbin with one color of thread and the top with a very different color so that it's easy to see what is going on with each of them.
Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing.Keep sewing a few inches at a time until you havethe results you want. Now you're tension is where you need it
Good luck! You'll do fine!
May 15, 2011 | Husqvarna Designer I
Help setting Viking Designer I machine for free motion quilting
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Apr 29, 2009 | Bernina Activa 140
Password For Viking Designer SE
actuall she/he means is after you hold down the back and pivot foot button and turn on the machine, it will pop up with a dialog asking for a password..
Jan 12, 2009 | Husqvarna Viking 1
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
