Question about GE WBSR3140DW Top Load Washer
GE WHRE5550K2WW has a continuous blinking light on motor what is wrong
  • Mel langford Nov 04, 2012
    It is filling and draining but when agitating it is making a terrible noise and it will not spin after draining.
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
Model whre5550k2ww. Why does it start to fill with cold water then switch to hot water?
Even on a cold wash cycle, some hot water is added to dissolve detergent if powdered detergent is being used.
Aug 03, 2015 | GE Washing Machines
I have GE WASHER whre5550k2ww... i am filling the water bu at the same time water is draining from drain pipe. Can anyone help me out?
sounds like the drain is too low if water just runs through the system usually drains into a stand pipe 3 foot tall of so
Mar 04, 2015 | GE WBSR3140DW Top Load Washer
Whre5550k2ww
The motor/inverter on this washer stores fault codes. The LED you see blinking will blink once every second non-stop when in stand-by mode and twice every second non-stop when it should be running. If there is a fault code the LED will blink a certain number of times then stop for a few seconds. Some of the fault codes not allow the motor to operate. Post back the blink code.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE WBSR3140DW Top Load Washer
How GE washer that will fill with water but will not agitate replaced lid switch and ck belt motor will not run
Check the water level sensor. See if it is clogged with softener. The other things that you need to check are the voltages to the motor and see if the transmission is ok. Also the drum might be loose on the drive splines.
Sep 17, 2012 | GE Clothes Washer Start Pause Button...
Whre5550k2ww
It could be the noise filter , a small part similar to a capacitor connected to main power entrance .
Oct 04, 2017 | GE Washing Machines
Ge washer whre5550k2ww control lights come on but nothing else
This might be a problem with actual switch in lid. Washing machine will NOW WORK, if the switch in lid is not working. It is there for safety, so small child will not reach in when machine is in use and get injured. Machine is designed to only work if machine is closed and switch under lids is working.
Apr 07, 2012 | GE Washing Machines
I have a GE washer model WHRE5550K2WW. we had a power surger which stopped the wash completely. I replaced the curcuit board behind the control switch witch the allowed the machine to fill,but would not...
Built into the wire harness from the machine control to the inverter board for the motor is a fuse..saddly the only way to replace the fuse is replace the wire harness
GENE
Sep 08, 2011 | GE WHRE5550K Top Load Washer
GE Washer Motor over amp?
If that's the only thing wrong with it, then go to http://www.appliancepartsdepot.com
They are about the most reasonable priced place I have found.
Dec 24, 2007 | GE WBSE3120B Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
